Stiffer springs for Baja 5t rear shocks?
MA
Where can I get a set of springs with higher spring rate for the stock Baja 5t rear shocks? I'm using them for custom project project and the stock springs are a bit too soft. Thanks for your help!
WI
RE: Stiffer springs for Baja 5t rear shocks?
you can use the HPi springs
the have blue(med) and also yellows
http://www3.towerhobbies.com/cgi-bin...?&I=LXTLK6&P=Z
http://www3.towerhobbies.com/cgi-bin...?&I=LXTLK7&P=Z
FL
I was looking at the springs from DDM and was wondering if they're all the same, just different colors? or is there a hardness value for the individual colors?
MB, CANADA
ORIGINAL: ByronRC
