beval gearbox???
WA
beval gearbox???
any one ever used 1 or know any thing about them???
it seems in my mind what i am or would be wanting to use for my current project idea.... the oil weight is variable
RE: beval gearbox???
I have something very similar to that I am selling, its a worm drive rear, I will post some pics today, but right now Im off to race, speak soon if your interested.
Yup, I was originally going to use it for my project, but I came across a Skellenger, so didn't bother, I was about to put it up on fleebay...
WA
what i posted is a 2:1 gear reduction transmission for industrial applications i was thinking to use it as a central differential um i did quite a bit of googling but really couldn't find much in the terms of pricing
speedypetey61 thats not exactly what i am looking for (beings its off set) it would have to be inline....
http://www.powerjacks.com/Bevel-Gear...olid-Shaft.php
ORIGINAL: speedypetey61
The axle is offset, but can be moved, cut or adjusted, it is 24 inches long at the moment.
ORIGINAL: bentley marshall
yes but what is it out of ??? a lawn mower or something ????
Yup, I have a buddy who built a 1/4 scale monster truck with 2 of these..
BC, CANADA
hmmm, wonder if the wife would notice if i pulled the drive outta our self propelled (yep she cuts the front lawn bless her I prefer the ridem so i can drink beer as i cut)
i like the pinion off set as it would be way better for my centre shaft angles.. time to do some scavenging at the local lawnmower repair place
IN
TORO makes a similar one... You may want to replace the axle bushings with bearings though!!
http://www.partstree.com/parts/?pn=106-3956
i have 2 ot those toro ones they dont look that strong and the gears a strate cut not realy ideal if you want to put any hp thru them allso only one bearing on the pinion shaft and gear mesh isnt that great eather
If you wanna run HP you need a Skellenger, even better would be the New Era versions, they are much stronger, or you can stop beating around the bush and grab yourself the best quick change rear you can find....
http://www.rcburnout.com/1-4-scale-m...-rear-t544.htm
Bob Smith out of NY makes these indestructible master pieces.....
So the original post was for a gear box for a project, I think the toro's or anything similar would be fine, otherwise take your pick from what I listed above depending on how much power your gonna run.
