Best oil?
Hi. <span lang="en" class="short_text" id="result_box"><span class="hps">What is the best</span> <span class="hps">oil for</span> <span class="hps">Zenoah g290?
</span></span> |
RE: Best oil?
That's a controversial question...
Whatever you can find locally reliably, most people say to stick to 25-32:1 on car/boat engines, I run 32:1 myself on every 2 stroke I own. just get an oil that's meant to run at that mixture and go for it. |
RE: Best oil?
Ok. Someone know how many liters g290 zenoah can drive? And is it better than CY?
RE: Best oil?
ORIGINAL: kaktus00 Ok. Someone know how many liters g290 zenoah can drive? And is it better than CY? Do not buy oils formulated for lawn and garden equipment get good quality oil used in the ATV or Motorcycle business. Some brands if you can find them that are proven. Maxima Castor 927 Motul 800 Polaris Ves Gold Mercury Quicksilver Amsoil Sabre Always run at 25:1 running less oil does not create more power that is a missconception that alot of people have. The entire purpose of the oil and ratio in our small engines is for Cooling, Lubrication and creating Compression. Zenoah states that inspection of their motors should occur every 25 hours, Replace jug and piston if showing wear. Zenoah has much better plating than CY. |
RE: Best oil?
both the oil and cy v's zenoah subjects have been flogged to death many many times here on rcu and other forums
RE: Best oil?
Castrol A747 25:1 ratio is what ive ran past 7+ years with no probs :)
RE: Best oil?
Plan Castrol oil 10oz per gal.
