Grind the edges off my Zenoah crankcase?
I`m going to put this kit on next week :
http://www.oneillbrothers.com/rccar/...achined_wc.htm Do I have to do something to my Zenoah crankcase in order to make it fit properly? I seem to remember that someone mentioned something about "having to grind the edges off the crankcase in order to make this kit fit, is this correct? If so, how do I do this grinding properly? See my crankcase below: http://i42.tinypic.com/2hgbcli.jpg |
RE: Grind the edges off my Zenoah crankcase?
It will bolt rite up, but if you are going to change the bearings and seals it might not be a bad thing to see how the ports line up, I installed that exact kit on a zenoah. I had to grind some of the case away, so the transfer ports lined up perfect. Not areal big deal though, if you put it on sa stock case you would be just fine.
What I did was with the case split and put the cylinder on one case half and make sure the bolt hole lined up and see how the transfer ports line up to the case. This can be done on each side. |
ORIGINAL: clubin It will bolt rite up, but if you are going to change the bearings and seals it might not be a bad thing to see how the ports line up, I installed that exact kit on a zenoah. I had to grind some of the case away, so the transfer ports lined up perfect. Not areal big deal though, if you put it on sa stock case you would be just fine. What I did was with the case split and put the cylinder on one case half and make sure the bolt hole lined up and see how the transfer ports line up to the case. This can be done on each side. |
