RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Giant Scale Cars (http://www.rcuniverse.com/forum/rc-giant-scale-cars-234/)
-   -   HPI BAJA 5B STARTING PROBLEM (http://www.rcuniverse.com/forum/rc-giant-scale-cars-234/9106668-hpi-baja-5b-starting-problem.html)
kinghuff75 09-18-2009 08:36 PM
I FILLED UP MY BAJA WITH GAS AND LIKE THE DUM DUM THAT I AM I SPLASHED SOME ON MY AIR FILTER AND MIGHT HAVE PUMPED THE THE BALL ON CARB TO MUCH ANYWAY I WAS GOING OUT TO RUN MY BAJA I TURNED ON CHOKE PULLED TILL IT FIRED THEN TURNED OFF CHOKE PULLED AGAIN IT FIRED THEN STALLED I TRIED TO START IT AGAIN PUT HAD NO SUCSESS PLS HELP ME AS I AM NEWBIE BAJA 5B OWNER THANKS
savagecommander 09-18-2009 08:58 PM
RE: HPI BAJA 5B STARTING PROBLEM
if it fired when the choke was on, than you have gas and spark- squeeze your trigger to open the throttle a bit(BUT JUST A BIT)- is it cold where you are at? and have you run the baja in your climate before?
this helps too
http://www.youtube.com/watch?v=6tMUfbQCzI8
cheezer1222 09-18-2009 09:22 PM
Could be that it's flooded. Almost all of my new engines want to flood when I first start them.
kinghuff75 09-18-2009 09:46 PM
i hope it's just flooded cause it was running amazing 2 days ago the store where i get my parts from told me to leave it sit with throttle wide open to let gas evaporate also told me to check spark plug, could be wet from flooding
but what i don't understand is why did it fire with choke on then again with choke off and then stall 1 sec. later and now i can't start it, it's been about 4 hr now im trying without taking sparkplug out to check for dampness
kinghuff75 09-18-2009 10:16 PM
pls if u know or think of anything related to my problem don't be shy leave a post i value your opinion's greatly thanks
cheezer1222 09-18-2009 10:33 PM
If it is getting too much fuel, causing it to flood, what I usually do is lean out the low speed needle until I can get it to start again. Then once you get it started and running richen it back as close to the stock settings without it stalling as you can.
kinghuff75 09-18-2009 10:39 PM
is it possible my sparkplug is bad and is leaning it out when idle gets faster or slower ?
cheezer1222 09-18-2009 10:46 PM
Like savagecommander said, your spark plug is probably fine, but if you want to check it, unscrew it from the cylinder head. While still attached to the coil touch the end of the spark plug to a metal part of the car (cylinder head or pipe usually works fine), and give the pull start a couple of yanks. If your spark plug is good, you'll see a nice little spark in the gap at the end of the spark plug.
As far as leaning goes, it is faster.
kinghuff75 09-18-2009 11:10 PM
thanks for all your posts ppl i will take all advise and try to start
sparky 25 09-19-2009 02:28 AM
Could be the spark plug,
the ngk plug in my new cy26 only lasted one tank,
it just stopped sparking, i replaced the plug and it runs fine now
kinghuff75 09-19-2009 03:12 AM
i pulled the spark plug out and at first it wasn't sparking but after wiping off the wetness from it i pluged it into coil and touched clylinder head with it while pulling the pull start and i saw spark so i put it back in and put choke on it fired up after 1 pull but when i turned choke off and tried starting again it was a no go so pulled out the plug again and noticed that it was all full of gas at tip where spark is so now im just leaving it sit for a few hours to let gas in cylinder evaporate, hopfully it will start any suggestions again on this would be greatly appreciated, also is it normal to see some moisture on plug by the way it was allblack aswell but afteri wiped it with a rag... like i said it started sparking again
sparky 25 09-19-2009 05:30 AM
Try resetting your carb,
it maybe getting too much fuel which is why it wont keep running,
to reset the carb turn the two screws on the side of the carb clockwise all the way in,
just until you feel a slight resistance, do not force them,
then turn each screw counter clockwise one and a quarter turns out, this is a good starting point on the cy engines,
if your baja does not start at these settings try and up the idle a little bit,
if that fails to start it maybe the spark plug is not sparking bright enough,
in this case you should replace the plug for a new one
kinghuff75 09-19-2009 10:05 AM
i have another question, is it normal to see some moisture on tip of spark plug? and iv'e come to conclusion that i need a new spark plug cause now it won't spark at all  i check for spark by touching tip of plug to cylinder head while pulling on pull start and oh ya spark plug is pluged into coil while doing these steps yesterday i some spark and now it's 9hrs later i tried to start after leaving it sit all night  and still no go so pulled out spark plug again to check and see if it was sparking and to my surprise there was no spark
davido666 09-19-2009 11:40 AM
Get a new plug and with the plug out of the engine turn the car so the spark plug hole is facing the ground and pull the engine over a few times and see if it blows out excess fuel. It might be flooded and you have excess fuel and oil in the crank case. Then put in the new spark plug and try pulling it over a couple of times. Make sure you don't over choke the engine because it will flood it. To much gas on the plug will prevent it from starting.
kinghuff75 09-19-2009 12:40 PM
i got it started ppl by installing new plug fired up 2 pulls
thanks every 1 for your help and suggestions
SAVAGEJIM 09-19-2009 01:29 PM
No prob!
Be sure to get like a box of extra plugs, because once you get to thee point that you are pulling and pulling and pulling but no ignition, the plug becomes fouled from the charge richness during start up (namely becaue the choke is on and more fuel than air is going into the combustion chamber).
Nice thing about plugs is you can get them cheap at your local automotive store; better yet, gasser blugs are cheaper than nitro plugs in some auto stores!!!!:D
sparky 25 09-19-2009 02:32 PM
Nothing like taking all the glory, eh savage jim[sm=lol.gif][sm=lol.gif][sm=lol.gif]
im in a jokin mood today:D
monsterbrad 09-20-2009 09:17 AM
I would have changed the plug long before that :D
They are not all good right from new I have had a few 2 stroke plugs fail
Also check the gap on the spark plug I have had a few people tell me there's were way off
EngageRC 09-23-2009 12:51 PM
Send the defective plug back to HPI for refund.
46u 09-23-2009 03:10 PM
Quote:
ORIGINAL: EngageRC
I guarantee HPI stands behind there items MUCH better then you do yours![X(] Probably was not the plugs fault.:D
EngageRC 09-23-2009 04:23 PM
your guarentee worth jack!
46u 09-23-2009 06:04 PM
Quote:
ORIGINAL: EngageRC
Do not need one as I do not have a RC business! :D By the way it is spelled guarantee. :eek: I do know HPI has GREAT customer service as I have been running there vehicles for over 10 years. :D
SAVAGEJIM 09-23-2009 10:11 PM
Quote:
ORIGINAL: EngageRC
As for an RC that does not start, would you be willing to do customer service and help the noob troubleshoot?
I bet if this guy called HPI, HPI would help him troubleshoot his RC and help him get it started and going.
He is here first because he actually wants to learn how to get his RC started and we are helping him. But if everything we do to help him is not enough, I have no doubt that HPI will fix his problem; even replacing the entire engine if need be.
As for replacing a bad plug on a new RC, if one of your RCs you sold had a bad plug, would you take the time to replace that bad plug for your customer?
SAVAGEJIM 09-23-2009 10:14 PM
Quote:
ORIGINAL: sparky 25
NP, the alleviation is actually a good thing! :D
EngageRC 09-24-2009 01:01 AM
We have the entire factory behind us.
KM will go the extra mile to fix the problem.
some talker here been bashing km, yet the km believers are happy with their baja.
show me your km? if you don't have one, how do you come to conclusion of support etc?
