radian banana
NY
radian banana
I got my radian today and the fuse looks like a banana the line or the joint is loose or needs glue
the line on the thin end of the fuse right side of fuse
the left side looks like a 1 piece fuse but the left side looks like 2 piece
any one have that problem with the regular radian
thanks..
thanks..
MO
RE: radian banana
HI,
The description of the fuse parts sounds typical. Being crooked however is not. Foam can sag if it has gotten like hot in the car. Especially if something was on the fuse.
Some people have used hot water to remove dents and such that might help.
If it arrived that way I would return it however.
The straight ones are a ton of fun so hang in there!
