Combat Models F-16 Slope Soarer - Need some help
MI
Hello,
I just bought a Combat Models F-16 Slope Soarer that needs to be finished. It looks like it is new out of the box but needs to be finished to fly. I don't think anything has been done to it so i'm starting from scrach. This my first attempt at a foam plane and and I'm looking for any helpful pointers/tips/advise any of you may have. Any help on his would be greatly appreciated.
Thanks in advance.
Tim
[email protected]
Thanks in advance.
Tim
[email protected]
My Feedback: (10)
RE: Combat Models F-16 Slope Soarer - Need some help
I also have one of these, but I havn't done any building yet. I think I am going with the powered version. If you have never used foam before it is real easy. I dont use epoxy for the glue, if you have time you may want to use elmers probond, or any other polyurethane glue. I also use a woodpecker to increase the bond surface. Since you are soaring you can finish with latex paint. Be careful of spray paints, you may want to do a test piece. Check with the combat guys. They usually have a number of tricks to be quick and inexpensive when working with foam. I am going to glass mine, like I said I am going with the power version and need the strength and residue protection.
Do a search for Combat Models, I think they have a construction video available for a deposit.[sm=pirate.gif]
MI
Hi Guys, I have the C.M. f-16 and also have the assembly instruction. If your interested, email me your address.
Tim
[email protected]
Tim
[email protected]
CA
How is the construction coming along??? Thinking about getting one myself!
Let me know
is this the same model as used for the powered version?
Let me know
MI
Hi Kev,
It is very simple to put together. I added 2 strips of the packing tape with string in it on the wings for strenth. Other than that, you glue the stab in, glue the bottom half of the fuse on, and the rudder into it's slot and it's about done. The elevator and alerons are balsa.
It is a nice kit and i was lucky enough to get all the hardware with it. I have read posts on here about kits that were missing parts and getting them was a pain... just to let you know...
Tim
[email protected]
Tim
[email protected]
CA
RE: Combat Models F-16 Slope Soarer - Need Copy of Manual
Hey Guys , Anybody able to photo copy their construction manual????? I just received an opened kit and want to start to build , but don,t want to blow it by guessing. I'll pay for materials and postage. Combat Models has yet to return my emails . Please P.M. If you can help. Thanks , JEFF
Hi --
I have an almost complete F-16 Slope Soarer manufactured by Combat Models, Inc.
Two Questions:
1. My kit is MISSING the foam bottom-cover???? Does anyone have one for me? Or does anyone want to sell me their kit? Please email me at [email protected]
2. Does anyone have the CONTACT information for Combat Models, Inc. What is their PHONE NUMBER or website? The address on my instructions that came with kit state:
Combat Models, Inc.
2128 48th Court
San Bernardino, CA 92407
Also note, my instrustions state the the center of gravity (CG) is 4 3/4 inches behind the forward seam between the foam wing and foam fuselage.
Two Questions:
Combat Models, Inc.
2128 48th Court
BTW, I found the contact information and web address for Combat Models, Inc.--the manufacturer of the the F-16 Slope Soarer...
http://www.combatmodels.com/ (see F-16T -- kit is for either power or glider)
Combat Models, Inc.
P.O. Box 1024
San Diego, CA 92150
(858) 513-4267
[email protected]
Combat Models, Inc.
P.O. Box 1024
San Diego, CA 92150
(858) 513-4267
[email protected]
My Feedback: (10)
Blue foam is what home builders use on the outside of your house for isulation. You should be able to get it at a home improvement store like Lowe's or Home Depot. I am aware of the model you are referring to, I have one. From what I know CBM only ships when they want, which means you may wait a while.
