RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Ideas for a micro DLG
Reply
Old 01-24-2012, 06:09 PM
skater_719
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Ideas for a micro DLG
After many years of powered flight, I have caught the glider bug, I have a couple electric gliders, that I have a blast flying. Lately I have been looking into DLG's and have a few questions about building one. From my experience it seems when it comes to thermalling, generally bigger is better, but would enjoy something small for the back yard, and something I can keep in the trunk for spur of the moment flying. I would really like to build a small dlg, between 30-40". First thing I am having trouble deciding, is what material would be the best to use. For the wing I was planning on using 1/4" balsa sheets and just sanding out the airfoil, seems for the simplicity and weight, wood would be the way to go, but I have never built anything like this, so do you guys think any composites or foam would be more weight friendly and rigid? My biggest undecided material is the fuse, I have not used composites before, but I have been wanting to give it a try, I'm worried balsa would be a pain to get to bend for the tight compound curves a micro glider fuse would entail, which is making me think carbon fiber would be more reasonable. The setup I plan on using is a Hitec electron reciever, with a 100mah 1 cell lipo, and 2 nano servos for either V-tail or just classic rudder elevator setup, another undecided part, are there any advantages between the two? Which would give more authority since there wont be any prop blast to help? Feel free to share your Micro Dlgs if anyone has one. Hoping to start this project within the next couple days. Thanks for any advice
skater_719 is offline
Old 01-25-2012, 12:15 PM
BMatthews
Moderator
BMatthews's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Ideas for a micro DLG
There's lots of options. But for now check out the Charles Rivers site and Mark Drela's Apogee at;
http://www.charlesriverrc.org/articl..._apogeehlg.htm
It's intended for direct javelin like hand launching but I suspect it would be pretty simple to convert to DLG. The big first step would be to convert it to a separate vertical and horizontal fin design instead of the V tail. The more regular style setup seen on many DLG's would tend to damp out the yaw during launch more easily.
BMatthews is offline
Old 02-10-2012, 06:36 PM
skater_719
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well i went ahead and built the apogee 36" and had serious cg issues with it being tail heavy due to using 4.6gram servos and such a light lipo reciever battery.i really hate adding weight so i experimented with removing the tailboom and tail to make it into a flying wing, and added a rudder off the back of the pod, and put 2gram servos in the wings.for elevons. It now can achieve a good range for the.cg.dependimg on reciever and battery placement. I started off with the cg far forward for.the first toss and had almost no elevator authority, so af
Old 02-10-2012, 06:45 PM
skater_719
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well i went ahead and built the apogee 36" and had serious cg issues with it being tail heavy due to using 4.6gram servos and such a light lipo reciever battery.i really hate adding weight so i experimented with removing the tailboom and tail to make it into a flying wing, and added a rudder off the back of the pod, and put 2gram servos in the wings.for elevons. It now can achieve a good range for the.cg.dependimg on reciever and battery placement. I started off with the cg far forward for.the first toss and had almost no elevator authority, so after many cg adjustments it just does not seem like i.can make it stable, its either insanely.sensative or completele mush. I guess such a small chord is not.helping. I have an idea for.a small horizontal stab on the rudder and or a canard style serface in the front. Any input would be appriciated. Btw i have tried al different amoumts of throw and expo settings.with no luck
Old 02-15-2012, 10:10 AM
soaringrace1955
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There are a few good threads on micro dlg also a few small gliders for sale.
soaringrace1955 is offline
Old 02-15-2012, 10:12 AM
soaringrace1955
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Whoops didn't add they are on RC Groups
Old 02-23-2012, 03:21 PM
BMatthews
Moderator
BMatthews's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Skater, you're not able to make it stable because the airfoil has a negative pitching moment. That's why the tail was on there in the first place. To make a plank or very low sweep angle flying wing you have to start with a whole other airfoil that has a postive pitching moment. Airfoils with this trait act like the combination of a regular airfoil with a rearward stabilizer.
If you set up the wing with full span elevons you can "fake" the reflex in such airfoils by trimming in some amount of up trim to the surfaces. Aim for a balance point of around 20% back from the virtual leading edge of the MAC (Mean Aerodynamic Chord) and keep adding up trim to the surfaces until it glides well.
Old 03-14-2012, 08:02 PM
qldviking
qldviking's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just saw this thread, and got curious. regarding the pitch attitudes when you go tail-less, try trimming both ailerons up about 3-5 degrees for normal trim, you may need more or less depending in chord and aileron size
qldviking is offline
Old 03-22-2012, 03:00 AM
Cloudsoarer
Cloudsoarer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Take a look at the Mimi - an updated version of the Apogee.
Similar construction but more wing area and DLG tailset.
Weight is very important in Mosquito class DLGs, as you can see from the Apogee weight budget.
Modern batteries and receivers have helped considerabvly in this since the Apogee was designed, provided you use a longer nose and very light tailset with a wrapped carbon boom.
Correct balsa densities and careful construction are required to make a good small DLG.
The Apogee and Mimi need sub 5lbscuft balsa which is largely unobtainable. Therefore various built up balsa wing constructions have been designed from solid D boxs to sheeted D box with ribs. Also light .75 ounce glassed foam wings are good either hot cut or sanded, using either epoxy or polyurethane.
The Bug is another quick construct possibility with a lesser performance.
Cloudsoarer is offline
Old 04-25-2012, 03:58 PM
skater_719
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I lnow its been a while, but. I added full strip ailerons with.some up trim and can finally keep it flying although.its been a challenge to find any lift with it.
Reply
Display Modes
