Laser cut rib sets
Laser cut rib sets
I have the plans, a completed fuselage, canopy and finished empenage for a Dumas Hi Pro Soarer ( found in an attic) and was hoping there is someone out there laser cutting rib sets still like there was in the late 1990's.... I think the design would beneifit from a SD 7037 section over the designed section...
If here is someone out there, I have the wing chord and spar locations and sheeting pattern or can scan and send the existing pattern....I also have the taper for the outer sections... as it is a straight leading edge wing plane with a pretty wing plan form...otherwise it is back tto the DWG board, down load the section and go back to doing it the old way, by hand ...The plans assume you have the printed or die cut set of wing ribs...
