If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 3 of 3
  1. #1
    Join Date
    Nov 2010
    Georgetown, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Finishing & Painting Elapor Foam
    I just bought a Multiplex Easy Glider Pro RR. It is made of Elapor foam. I notice that the wings have a lot of circular surfaceblemishes from the mold, probably. I would like to remove these to have a much smoother surface on the wings.
    Any suggestions on how to remove these? Sandpaper?
    Also, can I paint Elapor, and with what paint?
  2. #2
    TIA's Avatar
    Join Date
    Jan 2003
    La Habra, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Finishing & Painting Elapor Foam
    You can use a fine sandpaper like 600-800 then use a water-based paint to spray.
    I've had great luck with the Tamiya line of spray paints as they do not interact with the foam molecular structure like most do.
    Great plane btw!
    Show us a picture when you're finished.
  3. #3
    Join Date
    Nov 2010
    Georgetown, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I finally got my Easy Glider RR assembled and threw it off my raised patio for its maiden flights. It flew very well, and in fact went farther than I expected it would and hit a tree. Now it has several dents in the wing's LE. Does anyone have a suggestion for repairing Elapor?These are dents, not breaks,so is there anything (heat?) that would spring them back out?If it were balsa, I would just put a drop of water on it, but I don't know what to do about Elapor.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
