Go Back  RCU Forums > RC Airplanes > RC Gliders, Sailplanes and Slope Soaring
Reload this Page >
Scratch Designed/Built Sailplane Fuselage
RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Old 12-25-2012, 05:50 PM
  #101
Nodd
Nodd's Avatar
Default RE: Scratch Designed/Built Sailplane Fuselage
Happy holidays guys.
I totally agree Scott, a fiber-glass or composite version of this fuselage would be the next logical step in this air-frame's evolution. Lets see how she flies first, then move on from there. (PM sent regarding the offer to help).
Old 12-26-2012, 10:00 AM
  #102
PatternPilot
My Feedback: (58)
PatternPilot's Avatar
Sent you another PM with more info....
scott
Old 12-29-2012, 10:07 PM
  #103
Nodd
Nodd's Avatar
Wrapping up the wing (again)
Apparently Untracote doesn't stick well to spackling. So I decided to re-mask the wing & paint the fiber-glassed center area...
Usual thing, took 20 minutes to mask her, 30 seconds to apply the paint...
Next I set about applying the covering...
Transparent white on the open structure, gray on the sheeted sections...
Love the way the light shines through the wing, that should look real nice overhead...
Well that's enough for today...
Old 12-30-2012, 07:36 AM
  #104
PatternPilot
My Feedback: (58)
looks good ...now you most likely shoveling snow
scott
Old 12-30-2012, 03:36 PM
  #105
thepamster
Looks great Nodd. I am on pins and needles waiting to see her fly as are you I'm sure.
Old 12-30-2012, 08:27 PM
  #106
Nodd
Nodd's Avatar
Yeah we got snow today, only four inches though. Weird though the town over from us got a foot. Can't wait to fly her but warmer weather would be nice.
The wires don't reach
I've never been one to use pre-made servo extensions as it's not that difficult to solder together a custom length of wire if need be. Here's a great tip I picked up watching Bruce from xjet & rcmodelreviews on YouTube.
First I cut off the servo plug & find myself a spare length of servo wire...
Next I stagger-cut the wires so the connections aren't all in the same spot...
Bare the ends...
Twist them together...
Add a smidgen of solder to each...
Bend em over...
Slip a length of heat-shrink over the whole thing...
And we're good to go. I like this technique, no need to fiddle about insulating each wire separately. Thanks Bruce...
Back to the covering
I added the black visibility panels...
Started work on the outboard panels...
That'll do for now, more soon...
Old 01-01-2013, 08:10 PM
  #107
Nodd
Nodd's Avatar
Got-ya Covered!
Finally finished up the covering today...
I know you probably want to see how she looks assembled but I'm an evil bugger, you'll have to wait until she's complete. We're getting real close though :-)
Old 01-02-2013, 12:34 AM
  #108
colmo-RCU
colmo-RCU's Avatar
Put it together and show us!!
Old 01-02-2013, 12:32 PM
  #109
DeferredDefect
DeferredDefect's Avatar
Looks great-
It looks decidedly "bird-like", especially that fuselage! One thing that caught my interest is how much that transparent white covering looks like fabric- kinda retro in appearance.
Lets see her in the air!
Graeme
Old 01-04-2013, 08:42 PM
  #110
thepamster
"NODD!!!!!!!!!!!!!!!!!!!!!!" is what I yelled at my computer while you dangle the "not assembled" beauty in front of me.
Old 01-05-2013, 02:01 AM
  #111
Tinkrerpilot
TEASE!!!!! Sure looks good ..............
Old 01-10-2013, 08:02 PM
  #112
Nodd
Nodd's Avatar
She'll be together soon enough *evil grin*
Yeah I'm liking the transparent white covering, adds a touch of retro class. Its not the look for every plane but I think it works for this one.
Spaghetti for Dinner
I picked up this nifty six pin connector to power the wing...
I wanted to avoid having four connectors, one for each of the wing's servos. The red positive wires connect to one pin, the brown ground wires connect to another pin. Then each of the four orange signal wires goes to its own pin...
I'm still deciding if I should glue this in solid or leaving it loose...
Here's the other end exiting the bottom of the wing...
Shockingly, everything seems to be working. That never happens! *grin*...
Now that the servos have power I can proceed with installing the flaps & aileron linkages.
Old 01-14-2013, 04:48 PM
  #113
Nodd
Nodd's Avatar
On with the build
I finished hooking up the control linkages...
WARNING: The following technique has the potential to go horribly wrong in all sorts of unexpected ways. If you try this take extreme care.
Although pretty close, I noticed the gap between the fuselage & spinner was pretty uneven...
Then I had an idea how to even that up. I slipped a piece of sandpaper onto the folder's hub...
Then I powered up the motor to around 10% & let the sandpaper do its thing...
That worked pretty well, nice even gap...
With the prop installed I stuck her up on the balance stands. Weirdest thing ever, she balanced perfectly, no extra weight needed. How often does that happen, especially on a scratch designed airframe?..
Old 01-14-2013, 04:53 PM
  #114
Nodd
Nodd's Avatar
And then I realized there was nothing further to do...
COMPLETE!
Seven months in the making, she's finally ready to fly, woohoo!
No matter what happens from here on out, that was a great build. I've learned so much, couldn't have done it with out you folks here online. A heart-felt thanks to everyone who contributed.
wingspan: 105" (2667mm)
weight: 69 oz (1956 g)
wing loading: 12 oz/sq.ft (38 g/sq.dm)
cubic loading: 5.21 oz/cubic.ft
stall speed: 17 mph (28 km/h)
I was hoping to maiden her this Wednesday but the forecast is for rain/snow. I'll keep you posted. And yes there will be video, flight reports & all that good stuff. Thanks again everyone.
Old 01-14-2013, 05:03 PM
  #115
PatternPilot
My Feedback: (58)
Nodd,
And your going to let a little rain and snow ruin your fun.... Can't wait for the reports... Just got a new order of Epoxy in.... Hint Hint..
scott
Old 01-14-2013, 05:51 PM
  #116
thailazer
thailazer's Avatar
Gorgeous! I am sure you mentioned this earlier in the thread, but what CAD software are you using? The early renderings look great.
Old 01-14-2013, 06:22 PM
  #117
longsoar
longsoar's Avatar
Nodd,
Looks great! Congrats!
I have one question - with full down flaps and ailerons is there still a gap between them? Looking at the pictures it seems they may touch. Not a good thing in the air.
Looking forward for great flight videos!
Maybe some day we can fly together - I am like 2 hours away in PA.
cheers
Mark
Old 01-14-2013, 07:14 PM
  #118
SkidMan
My Feedback: (17)
Beautiful! It is a work of art.
I'm looking forward to the flight reports. Best of luck.
Old 01-15-2013, 03:53 AM
  #119
da Rock
ORIGINAL: longsoar
Nodd,
I had the same question. But about all that needs to be done is remember not to deploy the flaps while the ailerons are deflected. Even then, the flap on the conflicted side will probably scrape past. Ailerons probably don't deflect very far at all. It is worth checking to see, of course.
Old 01-15-2013, 11:41 AM
  #120
iron eagel
iron eagel's Avatar
Very nice, good luck with the maiden!
Old 01-15-2013, 06:40 PM
  #121
Nodd
Nodd's Avatar
Thanks guys. Yeah I'm pretty pleased with her.
ORIGINAL: thailazer
I use a combination of software...
3D Studio MAX
I use this for modeling my designs in 3D. It's total overkill for our hobby but I use it for my graphics business & it's what I know. There's plenty of free/cheap CAD software out there that'll do the basics.
CorelDRAW
I have a really old version of this from the '90s. I use that as my 2D vector editor. It's great for drawing shapes & printing plans. Again this is what I know so it's what I use. These days Adobe Illustrator seems to be the vector editor of choice. In my opinion that's become bloatware though. I like my simple uncluttered CorelDRAW, gets the job done without any fuss.
PhotoShop
Used for manipulating photos & other rasta based graphics. This is usually the final step in creating my graphics. It's where everything comes together & gets pretty.
ORIGINAL: longsoar
Nodd,
cheers
Mark
I'll be at most of the New England RC events again this year. Chances are we'll bump into each other. Just look for the guy in the goofy hat & amber sunglasses *grin*
Yeap it seems I have an issue with control surface binding just as you predicted. I want to include my fix in this build log but it's something better suited to video rather than still photos. So here's a short video illustrating the issue & what I did to fix it...
Click here to view the YouTube Video
Old 01-20-2013, 03:15 PM
  #122
PatternPilot
My Feedback: (58)
Nodd
WELL ?
Had a great day here in Knoxville.. I joined a few DLG guys and flew my Radian..... Had some great lift for all..
Old 01-20-2013, 04:49 PM
  #123
Nodd
Nodd's Avatar
Stupid weather is not cooperating. Its either snowing, rainy, foggy or today, too windy. Fingers crossed this Wednesday will be good for the maiden.
Old 01-26-2013, 11:05 AM
  #124
PatternPilot
My Feedback: (58)
Well ??
Old 01-26-2013, 12:48 PM
  #125
iron eagel
iron eagel's Avatar
He probably going to say it was too cold.
It has been brutal this past week here.
