Finishing & Painting Elapor Foam
TX
I just bought a Multiplex Easy Glider Pro RR. It is made of Elapor foam. I notice that the wings have a lot of circular surfaceblemishes from the mold, probably. I would like to remove these to have a much smoother surface on the wings.
Any suggestions on how to remove these? Sandpaper?
Also, can I paint Elapor, and with what paint?
CA
RE: Finishing & Painting Elapor Foam
You can use a fine sandpaper like 600-800 then use a water-based paint to spray.
I've had great luck with the Tamiya line of spray paints as they do not interact with the foam molecular structure like most do.
Great plane btw!
Show us a picture when you're finished.
Great plane btw!
TX
I finally got my Easy Glider RR assembled and threw it off my raised patio for its maiden flights. It flew very well, and in fact went farther than I expected it would and hit a tree. Now it has several dents in the wing's LE. Does anyone have a suggestion for repairing Elapor?These are dents, not breaks,so is there anything (heat?) that would spring them back out?If it were balsa, I would just put a drop of water on it, but I don't know what to do about Elapor.
