RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Radian Pro DX9/18 full house set up file?
Reply
Old 01-03-2014, 09:16 AM
Wheats
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Radian Pro DX9/18 full house set up file?
I recently added a Parkzone Radian Pro to my RC hangar and I am looking for a full house set up file for the Spektrum DX9/18. All of the set up files I have found are for the DX6/7/8, which uses different programming. I called Horizon and they didn't have any DX9 set up files. Being new to gliders, I do not want to jump into the mixing for camber, reflex and crow blindly. Any help would be greatly appreciated.
Brian
Wheats is offline
Old 01-03-2014, 09:54 AM
SushiHunter
SushiHunter's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm basically in the same situation as you are. Just recently added this bird to my collection, plus I've never flown a glider before, let alone a power plant that is electric. What I've done is just flew the Radian around a few months to get a good bond going with it's flight characteristics. I'm now at the point where I'm going to do some flight condition programming with the radio. Like you, I'm also interested in setting it up with camber, flex, and especially crow flight conditions. Definitely keep posting the progress, I'll be doing the same.
SushiHunter is offline
Old 01-03-2014, 11:50 AM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A lot depends on how you plan to set-up the motor.
Glider pilots use the left stick for flaps and camber control and put the motor on a switch or a slider. What will you do?
This was written for a pure glider. Ignore any reference to spoilers.
Minimum Recommended Surface Mixes
After model memories, surface mixes are one of the great features that computer radios bring to the game. Input to one control can move 2 or more servos in a coordinated fashion to create the kind of surface control you are looking for. This can reduce the pilot's workload while providing very consistent behavior. In most cases, when it makes sense, these mixes can be overridden during the flight or can be turned on and off.
Where two surfaces are listed, the first is the master and the second follows, sometimes called the slave channel. I will discuss these in more detail later, but wanted to get the list part stated up front as people are usually looking for these lists. Most are focused on planes with ailerons or full house planes, but I note where even simpler planes can benefit.
The following list is what I would consider the minimum set I would want in a radio that would be used for flying sailplanes, be it thermal or slope. These minimum mixes may be available under the “airplane” menu and may not be called out specifically for sailplanes. Even entry level computer radios are likely to have these.
* Exponential on aileron and elevator. Rudder would be a plus. (all gliders)
* Flapperon/Spoileron - requires two aileron servos on separate channels
* Aileron differential - requires two aileron servos on separate channels
* Aileron-rudder mix (coordinated turns)
* Flap or spoiler to elevator mixing for landing and glide path control. This can be very useful on RES, REF or full house planes and aileron only planes that are set-up for flapperons.
The goal of these mixes is to make the glider easier to fly more smoothly or more efficiently with less drag and more controllability. In addition we gain some level of glide path control to assist with landing accuracy or to help us get out of booming thermals. The landing mixes can also be helpful to slope pilots to land their glides in tight slope sites. With these tools you can have a more enjoyable sport flying experience or be more competitive than would be easily achievable with a standard radio.
Glider Mixes and Flight Modes
Now we are getting to mixes that would normally be implemented with specific glider/sailplane programming. These are usually used on gliders that have ailerons or ailerons and flaps (full house) rather than R/E or RES gliders. Some of these may be able to be implemented by using your user mixes on a radio that does not have glider programming, but it can get complicated. I don't consider those glider/sailplane radios, but you can make them work to some degree.
Flight modes can be thought of as changing your radio set-up to meet the needs of a specific situation. They often involve a change to the shape of the wing to better meet a special situation. You can think of your normal flying set-up as your cruise mode. All of your settings are based on your basic flying needs while you cruise around the sky looking for lift.
Flight modes might include launch, thermal, reflex, landing and perhaps others. As you can see by the names, these are modes of flying that occur under special situations other than when you are cruising. These modes would typically be controlled by a switch which may move surfaces to presets, change expo or surface rates and might even modify other settings from your normal cruise mode.
An example of a launch mode mix would depend on what kind of a glider you are flying. If this is a winch or hi-start launched glider you might drop the flaps 20 degrees and the ailerons 20 degrees giving your wing a more under cambered shape. This might also include some up or down elevator, depending on your glider. This generates tons of lift but also creates more drag. While this might be detrimental during normal fight, when you have the force of the hi-start or the winch pulling your plane up, you can afford this extra drag to gain higher launches. Once you are off the line you turn off launch mode which puts you back in cruise mode.
If this is a discus launched glider, DLG, you might have a launch setting that includes a slight bit of up elevator and maybe a tiny bit of rudder mixed in to help get the launch straight. This would be controlled on a switch that is convenient to your non throwing hand so you can flip the launch mix off just after release of the DLG. Some people like this to be a spring loaded switch that can just be released upon launch. What mix and what switch you use is going to be specific to you and your glider but if you throw with your right hand you would typically want this switch by your left index finger.
Flight modes could change how you use one of your control sticks. For example you might have your left stick controlling the throttle of an e-glider during your launch mode then flip a switch to cruise and the throttle would no longer respond to the left stick. That left stick might now be responsible for your landing mix. The motor would no longer respond to the left stick.
You could go through the entire flight and not use all of these modes but they give you that extra measure of control or convenience when you want it.
How sophisticated and complex these modes will be depends on the software in your radio. The degree of control you have could be thought of as the difference between a basic sailplane radio and an advanced sailplane radio.
The Four Servo Wing
Clearly a four servo wing is of little importance on a 2 servo wing such as the typical DLG or many aileron only slope gliders. But if you plan to fly full house (R/E/A/F) gliders in the future you may want this ability.
One of the features that I feel sets apart the "sport radios" from the "advanced" radios is the ability to directly address all four or more wing servos, each on its own channel. The sport radios can fly a plane with 4 servos in the wing, but they require that the flaps be on one channel through the use of a Y cable. This means that you have 4 servos but you are controlling them on three channels. You don't have individual control of each flap servo.
Where the 4 servo wing support comes in handy is in trimming and in aileron-flap mixing. There may be others, but these are where I have used this capability. Typically you don't find this on a radio with less than seven channels, and most have eight or more channels. Read the manual or the specs and look for this feature. If you don't see it mentioned, look for how flaps are set-up. If both flap servos are assigned to the same channel, you don't have 4 wing servo control.
When you have both flaps on a Y cable you must trim them mechanically to get them synchronized. This is not hard but it is time consuming. It is very important that the flaps move together. Flap trimming can be done using servo arm/control horn arm placement. Then you can trim the flaps together using the radio to get that final zero point and the end point for down flaps.
However if you can address each flap individually from the radio you can do final trimming from the radio, which is a great convenience. You can also use an aileron/flap mix to have the flaps follow the ailerons for more, or smoother roll authority. I use this on my full house gliders when I am flying in windy or gusty conditions. This would be useful on the slope for aerobatics. This is not a necessary feature but if you are going to invest in a "serious" sailplane radio, you will want to be able to address the four wing servos individually.
aeajr is offline
Old 01-03-2014, 12:26 PM
Wheats
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the reply. I was hoping to keep the throttle in the traditional spot and not associated with a switch/slider. The Horizon full house set ups for the dx6/7/8 keep it this way...I think. I was hoping someone would have a dx9/18 set up file to ease the mixing/programming headache. Returning to the hobby after 25 years away has my head spinning with the new radio technologies. Thanks for your help!
Wheats is offline
Old 01-03-2014, 01:19 PM
SushiHunter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Same here and this is primarily the reason why I too recently got back into this hobby after around 9 years of being away from it.
Old 01-03-2014, 01:24 PM
SushiHunter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great information, thanks for posting. I had set up mine more like flight conditions with the use of a toggle. However, after reading this, I do like the idea to assigning a slide switch for the throttle while keeping the control surfaces on the stick. Good stuff! Thanks for posting it. Lots to do with it now
Old 01-03-2014, 02:20 PM
aeajr
aeajr's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My advice is, if you are primarily a power pilot then leave the throttle on the stick. That is where you expect it. Put your landing mix on a slider, a dial or a 3 way switch.
If you are primarily a glider pilot, as I am, then the left stick is my glide path control. That is where I expect flaps, flapperons or spoilers to be.
aeajr is offline
Old 01-04-2014, 08:19 PM
Wheats
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SushiHunter,
How much elevator did you mix in with the flaps? Does it pitch up or down dramatically when the flaps are deployed?
Wheats is offline
Old 01-06-2014, 08:22 AM
SushiHunter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SushiHunter,
I've not done any of the programming yet with the Radian.. I'm still waiting on the flap servo to come so I can replace the one that has locked up. Once I get that servo in, which should be this week sometime, I'll install it in the bird and then start doing this programming. I'll post the progress and mix information.
Old 01-06-2014, 08:53 AM
SushiHunter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm not so sure keeping throttle on the stick is something I would really have to do, because when flying this Radian Pro, I really only use throttle when getting the bird up to soaring alt or occasionally if I abort a landing and need to gain alt ASAP for another attempt. I don't think I'd have much of a problem adapting to the throttle on a slider just as long as the slider is on the same side of the radio as where I've had the throttle on the stick.
So far I've set up conditions on a three-way toggle for flaps up, flaps down and crow. Using another toggle I can create a few more conditions for camber and flex. I've not actually set up any of this on the bird as of yet since I'm still waiting for the replacement flap servo to come in. Hopefully this week that servo will come in and I can do some of this programming to where I can take the bird out and see how it reacts to such settings. I am starting to think that having all of the functions on one stick would be much easier then having multiple toggles to remember. I've seen some youtube vids that other glider pilots have made showing all functions like flaps, crow, camber and flex being on the one stick which I really like that idea not only because of the simplicity of all functions being on the same stick, but also because all the movements are adjustable.
Other functions that I can program into the radio is control reaction speeds both in regards to how soon the control surfaces react when toggled and how fast they move once they start to move. Real fun stuff that I'm looking forward to "playing around with" once I get that flap servo replaced. I may even need to pick up a few extra batteries just so I can stay out in the field longer between recharges.
Old 07-08-2014, 04:57 AM
Victory Pete
Victory Pete's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Brian
What Rx did you use for this. I am looking to do the same but the stock AR600 needs one more channel.
Victory Pete is offline
Contact Us Archive Advertising Cookie Policy
