RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
171" lANYU Minimoa
Reply
Old 03-13-2014, 06:07 PM
wingspar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 171" lANYU Minimoa
I've been flying a yellow KA-8 for about a year now and was looking for something different. I really like the looks of the vintage gliders especially the Minimoa. I also found that with its wider gull wing design, it was much easier to see up high. So, when BK Hobbies was having a closeout sale on the Lanyu Minimoa, I jumped at it.
It arrived today in a very large and stout box. This is just the perfect size sailplane for me. It's large but still is able to be towed without using one of the big tugs.
Took out the fuselage and examined it. This is a built up fuselage and not fiberglass. The forward half appears to be planked with thin plywood and no attempt was made to sand it smooth. I'm currently planning on striping off the covering and doing some filling and sanding before fiberglassing.
The painted on red trim was rough and there are areas of over spray.
The wings mount by installing screws into steal brackets. Then somehow yuu have to attach a piece of vinyl plate to cover the one inch gap between the wing and the fuselage. I'm rethinking how this is done. Possible change it over to carbon fiber tubes.
The air brakes that came with the kit are real nice and extent above and below the wing as the fully scale plane did.
I also like that all the control surfaces are removable.
ID:	1977810   Click image for larger version
ID:	1977811   Click image for larger version
ID:	1977812   Click image for larger version
ID:	1977813   Click image for larger version
Name:	WING ATTACHMENT.JPG
wingspar is offline
Old 03-14-2014, 09:55 AM
wingspar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i'm planning to strip off the old covering and recover it with solartex. This is waht I'm going to duplicate.
wingspar is offline
Old 03-14-2014, 06:32 PM
jetmaven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice color scheme , I think I'll steal it .
jetmaven is offline
Old 06-04-2014, 04:21 AM
Charlesd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
Have you started the build yet?
I just picked up the Lanyu 4.36 meter Minimoa and will start the build soon.
Charlesd is offline
Old 06-04-2014, 06:03 AM
wingspar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, it's done. It's not a kit I would recommend but for the price I got it for, I can't complain to much.
The forward part of the fuselage is planked with 1/32nd? plywood. You will find it especially easy to punch your fingers through if your not holding it at the formers. After trying to fix it a few times I stripped off the covering and fiberglassed the entire cockit area with two layers of 1.5 oz cloth and west system epoxy. I coated the back part of the fuselage with epoxy and no cloth. Now it is nice and firm with no worries on handeling it. Also there is no skid on the lower front and rear of the fuselage so I added it on.
The wings are held on by two bolts at the main spar area and a antirotation bolt in the rear. This leaves a one inch gap between the fuselage and the wing that is somehow covered with a plastic strip that just didn't work very well. At least for me. So I filled in the gap with balsa and plywood leaving an access holes for the bolts with little hatches held on by magnets.
On the right wing all the mounting bolts and antiroation bolts lined up perfectly. However, on the left they did not. When the two main bolts were installed, the rear antiroation bolt was about two inches!! off. Of course the wing incendence was way off also. So I ended up grinding down and shimming the other side of the lower mounting bracket so as to bring the antirotation pin into alignment.
I did used the airbrake included in the kit but couldn't get it to work properly driven horizintally. I changed it around driving it with a vertical rod. Now it works perfectly.
The canopy comes with some light framwork that needs to be assembled. Good luck with that. I scratch built my own framwork that is much more solid.
I also stripped of the covering from the wings and recovered it with Solartex.
Anyway, Got the tow plane lined up and the first flight should be this Saturday. :-) I'll post some pictures and a flight report afterward.
Good luck on your build!!
Dave N
wingspar is offline
Old 06-09-2014, 06:45 AM
wingspar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And fly it did this last Saturday. I was alittle concerned if a 55cc towplane would haul it up but under the skillful direction of Don Bailey, this proved to be a non issue.
Balancing right at the aft portion of the wing joiner proved to be just about right. Flew well and much better then my KA-8. It stayed up much better then my other Sailplane even with my nonexsistant sailplane experience.
The air brake/spoiler showed no tendency to pitch change when deployed.
Looks great in the air and is easier to see higher up compared to other models.
As this ARF required alot of "fixes", this is not an ARF I would recommend.
I'll be at the Northwest Aerotow at Monroe, WA near the end of July this year.
Dave N
wingspar is offline
Old 06-09-2014, 03:11 PM
jetmaven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well done sir , it's a thing of beauty.
jetmaven is offline
Old 06-10-2014, 09:41 AM
jeffEE
jeffEE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not to barge in on your post, but I just picked up a Graupner Minimoa 110" still new in the box. As this sailplane is out of production, I was looking for a little help. It is the version that has a fiberglass fuse and beech covered wings. Is there a place I can go to find any flying hints? And other than getting with the local Sailplane guys, any advice? Thanks in advance.
jeffEE is offline
Old 06-10-2014, 10:48 AM
wingspar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jeff, I'm not familure with that kit. Hopefully someone here with experience on it will chime in.
Good luck!
Dave
wingspar is offline
Old 06-11-2014, 09:27 AM
UStik
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www.youtube.com/watch?v=gaCVQOhqjtg shows that it's a slope soarer.
Here is some information. I'd agree with them regarding balance at 45%-50% (even 53%) of inner wing chord (the outer wings sweep back). That's a calculation result based on 6 aerodynamic decalage, meaning about 2 geometric decalage for a true Clark Y (not a flat-bottom something), which has zero lift at -3.8 angle of attack, and a symmetric stab.
UStik is offline
Old 06-11-2014, 10:53 AM
jeffEE
jeffEE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It looks loke a nice soaring plane. This could be fun
jeffEE is offline
Old 07-02-2014, 02:41 AM
Charlesd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wingspar,
I'm starting mine and added epoxy + fiberglass to the fuselage to strengthen the balsa strips.
Question: how and where did you install your tow release? For the rudder did you use a pull-pull system and how did you mount your servo?
If you have any pictures that would help. I have an idea of what I want to do but maybe you're installation may be better.
thanks
Charles
Charlesd is offline
Old 07-02-2014, 05:31 AM
wingspar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Charles,
I'll post some pics tonight.
Dave N
wingspar is offline
Old 07-02-2014, 08:28 AM
Charlesd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great !! Thanks
Another question while I'm at it. I've been reading on the french forms that some of the guys have had problems with the wing joiners with the 5+ meter version. Some of them have had the wings come off after 3 - 4 flights. The posts date back from 2009 so I ignore if the problem was fixed or not. Tonight when I get back I'll be checking the fixtures that hold the wings.
Did you do anything special on yours apart from the ant-rotation pin fix?
Charlesd is offline
Old 07-02-2014, 09:30 AM
wingspar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I haven't seen any issues with it on mine yet. Looks very strong with good quality steel being used.
Dave N
wingspar is offline
Old 07-03-2014, 05:54 AM
wingspar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The rudder is of a pull/pull setup with the elevator servo located just below the tail.
The tow hook consists of a wire loop in the nose with a wire pin that moves in and out supported by a brass bearing.
ID:	2011131   Click image for larger version
ID:	2011132   Click image for larger version
Name:	minimoa cockit.JPG
wingspar is offline
Old 09-17-2014, 01:27 PM
Charlesd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Wingspar,
I forgot a very important question: What was your final flying weight?
Charlesd is offline
Old 09-17-2014, 07:05 PM
ARUP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try RCAerotowing.com
ARUP is offline
Old 09-18-2014, 05:09 AM
wingspar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Charlesd View Post
Hi Wingspar,
I don't have an accurate way to measure its weight. My bathroom scale just is that good. :-(
Dave
wingspar is offline
Old 11-28-2014, 04:48 PM
Charlesd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bathroom scale would be fine. It's just to give me an idea. I'm still debating whether to tow it or install a motor.
Charlesd is offline
Old 11-29-2014, 06:38 AM
foodstick
foodstick's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I envy anyone that gets to see that doing slow flybys......
foodstick is offline
Old 12-02-2014, 06:33 PM
jeffEE
jeffEE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I did not sell it. I built it. Here it is. Now I just need to get a launch system, and find a nice day to try it out.
jeffEE is offline
Old 04-19-2017, 04:57 AM
Rcuniversedude
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Lanyu build
Hi Dave
The Lanyu Mlnimoa looks to be a big build. I just pickup up a slightly damaged one to get going.
i see what you mean about thr kit engineering not being great.
What was your final CofG?
Do ou have approx AUW? . Travel scales do the job for a few dollars
Do you still fly it?
Deano
Rcuniversedude is offline
