RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
X1-A v.4 RC Paraglider paramotor
Reply
Old 03-11-2015, 03:00 AM
BMR Paramotor RC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default X1-A v.4 RC Paraglider paramotor
Sales on Facebook and Ebay: BMR PARAMOTOR RC
***NEW RELEASE 2015***
Let's go flying!
Presenting the X1-A v.4 by BMR PARAMOTOR RC.
The X1-A is a premium rc paramotor, paraglider trike kit. You have to assemble it.
Features:
  • Made from marine grade aluminium
  • Laser cut from CAD drawings
  • Rear suspension
  • Front wheel steering
  • Built-in battery compartment with locking door. Dimensions L-155mm W-55mm H-40mm
  • Seat for your own pilot
  • Prop shroud (black)
  • 3 adjustable motor mount positions
  • Motor mount accepts a variety of motor sizes. Typically 36-45 size.
  • Multi configurable for servo setup. Can be flown with just 1 servo. Or you can fit it out with up to 4 servos - as shown in photos.
  • 75mm wheels
  • Riser bar pre-assembled
  • Suspension can be added to the front wheel by removing bottom spacers and adding your own springs.
  • Designed for use with my own BMR PARAMOTOR RC wings. Suited best to the 1.32 wing for a fully featured trike.
  • Approx Trike Dimensions:
Length - 360mm
Width - 350mm
Height - 390mm
What do you get? Whats in the box?
1 - X1-A v.4 kit. With all nuts, bolts, linkages, shocks, wheels etc.
1 - Instruction manual. Detailed instructions and progress photos for assembly.
Includes everything apart from the electronics, motor and wing.
When assembled, it will be a rolling chassis, ready for your own running gear.
What you need to complete:
1 12kg standard size servo (minimum - up to 3 standard size and 1 mini servo can be installed)
1 60Amp Speed controller
1 40 size motor @ 900kv
1 Tx and Rx
1 battery 4 cell 5000mAh to fit dimensions of battery compartment.
1 11inch x 8 prop
1 1.32 wing
The X1-A v.4 is the most sophisticated and configurable rc trike available. No other trike comes close.
***If you want the most awesome R\C Paramotor Trike available....then look no further.
http://youtu.be/TwDNZGR4RfQ
http://youtu.be/tgw89tUlQW8
http://youtu.be/j63GE28L1K8
BMR Paramotor RC is offline
Old 06-11-2015, 02:50 AM
TheMillionDollarMan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks like HobbyKing ones!
TheMillionDollarMan is offline
Old 06-25-2015, 10:26 PM
BMR Paramotor RC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LMFAO....you must be blind!
Old 09-24-2015, 07:28 AM
TheMillionDollarMan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, I can see clearly! Maybe the Trike look like a little better, but I saw your videos with the wing installed on it, and when I saw the wing, the bad quality explode in your face.
