RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Help with Robbe ASW-19
Reply
Old 04-21-2015, 07:02 PM
xxwolfyxx
xxwolfyxx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Help with Robbe ASW-19
I just picked one up minus plan and instruction book.
I have most of the assembly figured out. Need some help on the wings and what the CG is.
Wing issue is how the ailerons are hooked up. Looks like a bell crank setup but not sure where the hole in the wing is, the obeche is covering the cut outs and so it would be random poke with pin until I find it.. Plus I would rather just install servos in the wings not sure how to drill down the wing to run the wire. Or if I should cut the obeche and rout out the foam then replace the cut area.
There is a few other small things but wings and CG are the biggies.
If there is a plan or instruct book someone is willing to share or scan that would be great as there are a few thing that I need some clarification on.
Thanks.
xxwolfyxx is offline
