RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Staufenbiel fox pro v2
Old 05-08-2015, 02:26 AM
jondarlo
Default Staufenbiel fox pro v2
Can any one help with the balance point measurement for a Staufenbiel Fox Pro V2. The instructions are in german, and my translation by google is not very clear.
Old 05-08-2015, 11:56 AM
UStik
And how about showing those instructions here?
Old 05-09-2015, 01:40 AM
jondarlo
The instructions are-"Schwerpunkt: 40mm hinter der Nasenleiste". Can you explain what this means in English? I presume it means 40 mm behind some part of the wing, but where?
Old 05-09-2015, 02:10 PM
UStik
Correct, Nasenleiste is literally leading edge bar, but just say leading edge, which is straight on the Fox.
Tis model is scaled about 1:6, and absolutely "scale" would be a C/G between 35mm and 62mm, so 40mm should be pretty stable. Seems to be a good starting point at least.
Old 05-09-2015, 04:50 PM
jondarlo
Ok, Many thanks for the info. It is very nose heavy at 44mm, but I will start with that. Very pleased to have some advice from the Northern hemisphere to the Southern hemisphere down under.
