RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
The Sorcerer
Reply
Old 04-15-2017, 09:49 PM
KiwiKid
KiwiKid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default The Sorcerer
Here's a balsa bashing project I have been working on for a couple of years off and on The Sorcerer thermal glider built from Charlie Parker plans (produced in the early eighties).
Well, after doing a bit every now and then, we finally got the beggar finished. The model is designed to fly on the dual rudders only, but performance was pretty sluggish, so I added ailerons. These work really well and make it agile enough for general park flying, particularly when you let loose with the twirly bit on the front. Also should make a good light wind sloper - I hope.
Here's a vid of the maiden flight following the addition of ailerons.
https://vimeo.com/212457840
ID:	2210022   Click image for larger version
ID:	2210023   Click image for larger version
ID:	2210024   Click image for larger version
KiwiKid is offline
Old 04-21-2017, 08:35 AM
blvdbuzzard
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was thinking of making it a pusher and use this for an FPV / camera platform. I like the unconventional look to it.
Maybe needs a touch more dihedral to make the rudders more effective?
How slow does it fly? Would this be able to thermal at all?
Buzz.
blvdbuzzard is offline
Old 04-21-2017, 01:03 PM
KiwiKid
KiwiKid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Buzz, yes it would work well with a pusher/FPV setup. I have been playing around with a movable camera set up I got from Hobby King (see below), but struck a bit of a snag as HK cheaped out on the servos and they are too jittery, so will have to look at rebuilding it with better servos.
Yip, the model thermals like a champ - which is what it was originally designed for. In the vid I was just tooling around down low as it is slightly more entertaining than watching a glider thermal.
Here's a link to a RCG post that has the plans and a very good article in PDF format: https://www.rcgroups.com/forums/show...&postcount=625
ID:	2210734   Click image for larger version
KiwiKid is offline
