RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Help converting glider to electric
Reply
Old 11-10-2017, 07:37 PM
bobbailey
My Feedback: (40)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Help converting glider to electric
I have an old airtronics olymicp ii glider I would like to convert to electric. I have no idea what motor or esc to use. Thanks.
bobbailey is offline
Old 11-11-2017, 11:33 AM
Propworn
Propworn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you look at the Axi motors each one has charts at the bottom with battery, esc, and prop choices.
https://www.modelmotors.cz/
Propworn is offline
Old 11-13-2017, 04:31 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Look for a combination that will deliver 350-400 watts.
speedracerntrixie is online now
Old 12-07-2017, 09:34 AM
jollyroger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Esprit Models has them in stock. They are special Axi motors built for gliders. I bought one for my Sig Riser 100.
jollyroger is offline
Old 12-07-2017, 11:33 AM
bobbailey
My Feedback: (40)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys.
Old 01-01-2018, 07:14 AM
jollyroger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I bought one for my Sig Riser 100. Looks like a winner.
Can't wait until next season.......24" of snow in the yard more on the way. January promises to bring more.
Not happy.
Old 01-01-2018, 08:05 AM
bobbailey
My Feedback: (40)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks. May snow,at va beach wed nite.
Old 01-01-2018, 08:16 AM
jollyroger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just be thankful you don't live in Erie, Pa. 60" in 36 hours!!!!
Old 01-06-2018, 02:10 PM
Msflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Typically it doesn’t take a whole lot of motor to get a glider up in the air, but I just completed my BOT ep version I had on preorder forever and finally arrived right before Christmas. I went with the recommended motor, Rimfire 32 and a 3600mah 4s which I think is way too much! Should fly like a rocket, but I went with it because It seems to balance out perfectly at the recommended cog. Haven’t had the weather to get a maiden in yet, but it feels like a flying brick at just under 5lbs, 4lbs 9oz to be exact! But with its wing area and almost 10ft wingspan it should soar just fine. I think I will put spoilers on it eventually because it just looks like it will be a must, not sure why GP didn’t think it would need them, but I’ll do my maiden without... wish me luck!
Msflyer is offline
Old 01-06-2018, 04:43 PM
Propworn
Propworn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Msflyer View Post
Typically it doesnít take a whole lot of motor to get a glider up in the air, but I just completed my BOT ep version I had on preorder forever and finally arrived right before Christmas. I went with the recommended motor, Rimfire 32 and a 3600mah 4s which I think is way too much! Should fly like a rocket, but I went with it because It seems to balance out perfectly at the recommended cog. Havenít had the weather to get a maiden in yet, but it feels like a flying brick at just under 5lbs, 4lbs 9oz to be exact! But with its wing area and almost 10ft wingspan it should soar just fine. I think I will put spoilers on it eventually because it just looks like it will be a must, not sure why GP didnít think it would need them, but Iíll do my maiden without... wish me luck!
Tim Taylor says never enough power he he he!
Propworn is offline
Old 01-06-2018, 07:58 PM
Msflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow that things fast! The big ole BOT won’t be moving like that! If it does the wing will fold
Msflyer is offline
Old 01-07-2018, 08:08 AM
Propworn
Propworn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I saw a couple guys fooling with F5b ships and thought I might like to try one myself. True competitive machines were pricey so I settled for an introductory model called the Hawk F5B with an older Hacker carbon motor and gearbox turning a 17 X 15 carbon prop. The dang thing is so thin it disappears in 5 seconds straight up. Needs tones of room to fly and bleed off airspeed to land. A dang jet is easier to fly at least its big enough to see at distance. Both get there awful fast. Decided it wasn’t the most relaxing way to fly. The introductory model is enough excitement for me LOL.
Dennis
Propworn is offline
Old 01-07-2018, 09:58 AM
jollyroger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Most hot liners and and F5B have either flaps or spoilers to slow down. and or bring the ship down for points landing. When the timer is about to go off, and your ship is hundreds of meters up, spoilers go a long way to bring it back down in time hopefully to win the contest.
I actually watched the wings on a woody fold from too much winch.
Was not a pretty sight.
I have several gliders now and will start working on an old ship sold by Kirk Massey at New Creations R/C called a Millennium Falcon, fiberglass fuse, Obeichi sheeted foam wings and tail feathers. I Installed a Hyperion glider motor and added ailerons . Gotta get the servos for the rudder and elevator installed....someday.
Old 01-07-2018, 12:18 PM
Msflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default My BOT ep
Hereís a couple of pics of my bot ep. first glider of this size...
ID:	2250280   Click image for larger version
ID:	2250281   Click image for larger version
ID:	2250282   Click image for larger version
Msflyer is offline
Old 01-11-2018, 02:47 PM
jollyroger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Msflyer, That"s looking good.
What are you using for motor and prop?
Old 01-11-2018, 03:10 PM
Msflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Iím using the recommended motor, a Rimfire 32 800kv and the folding prop and spinner comes with the plane, I believe itís a 13.5x7.
Msflyer is offline
