RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Great Planes Bird of Time ep
Reply
Old 01-08-2018, 02:50 PM
Msflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Great Planes Bird of Time ep
I’m starting this thread on this Bird of Time ep version because I’ve got one, but haven’t had the weather to maiden it yet and I would love to learn anything I can about it. The Bird was perfect right out of the box, and the build went smoothly with minimal snags. One of the only snags I did encounter, which was no big deal, was the fact I had to mount a servo in that little hole in the tail for the elevator. Well, thanks to Ben at RCAirMods that problem went away for only 22$! Most all of his mods for the BOT arf will work on the ep version. The tail linkage mod,that lets you relocate the elevator servo up front under the wing,works flawlessly! Be sure to let him know you have the ep because the braided cable needs to be a little longer and he will ship it extra long for you to cut to length. He is a super nice guy and will help you in any way! I went with all the recommended set up that Tower Hobbies and Great planes recommend. Rimfire 32 800kv motor, Hitec 60amp esc and 3300 to 3600mah 4s LiPo. My receiver is a Spektrum AR6200 w/sat paired with a TM1000 telemetry module and a Spektrum Variometer with built in altimeter. Will also be monitoring LiPo volts and esc temp. I’m controlling the tails surfaces with 2 Hitec HS82mg servos. It balances slightly nose down at 3.75in from LE of wing. I’ll leave a few pics of my progress and would love to hear from others that have this glider. Seen a lot and read a lot on the arf version but not much out there yet on this one...
ID:	2250452   Click image for larger version
ID:	2250453   Click image for larger version
ID:	2250454   Click image for larger version
ID:	2250455   Click image for larger version
ID:	2250456   Click image for larger version
Msflyer is offline
Old 01-11-2018, 03:25 PM
Msflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Those who may not be familiar with this glider, go to Tower Hobbies web site and look up the Great Planes Bird of Time EP. I tried to post a link on it for this thread, but couldn’t because I’m a new member and haven’t posted enough. It’s a new product and is currently back ordered till lat February. I was able to snag one on a preorder of the last shipment. It’s very nice looking!
Msflyer is offline
Old 01-14-2018, 06:43 PM
Msflyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
https://www.greatplanes.com/airplanes/gpma1053/
Msflyer is offline
Old 03-22-2018, 10:26 PM
neilt162
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Around 2005 I had one from memory the only little problem the mate & I had was the spoilers were a little of a tight fit.We fitted dual servos for the flaps. Ours were built from plans so it was rather a large build job.Flights were great you need a good chair, a few bottles to ward off the dry throat and lots of time cause once this bird is up there it can ride the thermals all day long.
Have hun,
Neil
neilt162 is offline
