Robbe ASW27
Robbe ASW27
A gentleman donated a 3.5 meter Robbe ASW 27 to our club. The directions and the plans only discuss/show a tow release for use with a tug. Does anyone think there would be a problem towing this sailplane up with a winch if we add a tow hook?
Thanks in advance.
Thanks in advance.
My Feedback: (98)
Re: ASW27
Originally posted by Bill_Jehle
Rich,
Steel...looks like about 1/16 by 7/16. Each wing has one embedded. They are 5 inches long (beyond the root) and go into metal channels in the fuse.
Rich,
If you put a hook on it, make a imaginary line from the wing blades 30* forward and down to locate the tow hook safely. If you just put it where you would on a normal model it will be to far back because of the height of the scale body.
FL
no belly hook
I don't think you want a hook in the belly.
Take a look at;
http://www.soaringissa.org/tech_tips..._launching.htm
It's the Scale soaring association and they use 2 hooks on the fuse sides. Gives the layout for everything you need. They also ROG because throwing one of these bug 'uns is asking for major trouble.
I've winch launched a 100" scale sialplane, and that was OK. I'm working on a 4m DG-800, but it has it's own pop-up motor. I have not winch launched anything that big myself.
Take a look at;
My Feedback: (98)
Robbe ASW27
The armpit tow hooks are a good idea, but it does involve making up a special launch bridle. The tow hook on the bottom works also, I've launched my 4.2M ASK-21 that way. Your choice.
