RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
mounting control rods inside fuselage tube?
Old 08-15-2004, 04:21 AM
azenigma
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default mounting control rods inside fuselage tube?
I just received a NEsail Mini Floh E glider
http://www.nesail.com/detail.php?productID=128
The fiberglass fuselage narrows to a small tube after the wing all the way down to the v-tail. I can't figure out how to install the control rods, so that they will be supported in the tube to prevent bending. What is the best method the get them secure?
azenigma is offline
Old 08-15-2004, 09:43 AM
JWN
Community Moderators
My Feedback: (42)
JWN's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: mounting control rods inside fuselage tube?
I personally like Dubro's NySteel pushrod system, but Great Planes makes a setup almost identical to it. It's a steel 2X56 pushrod that runs inside a plastic tube the whole length just as you describe. I use these on everything from .25 - .60 size models. I secure them to the tail end of the model where they exit and the front near the servos. The middle is unsupported and I've never had a problem with flex. They aren't the lightest setup available which may make them unsuitable to a sail plane where tail weight is your worst enemy. But, you could always fab up a similar setup on your own using smaller piano wire and tube.
John
JWN is offline
Old 08-15-2004, 01:22 PM
spokman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Maybe you could use carbon fiber rods? Perhaps NESail has a recommendation? This is a good question to get answered.
spokman is offline
Old 08-15-2004, 01:52 PM
SST
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got an idea...When you route the outer nyrod rod tubes, run them in a ways, then put a gob of polyurethane glue on 'em, and insert them the rest of the way. The glue will expand when it dries, filling in around the tubes with very light, rigid foam. I've been experimenting with this stuff for all kinds of things, and if I have the time to wait for it to cure, I use it instead of CA as well as epoxy.
SST is offline
Old 08-15-2004, 10:32 PM
The R/C Man
The R/C Man's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How about a squirt of expanding foam.... That will hold them in there....
The R/C Man is offline
Old 08-16-2004, 01:08 PM
Rick K
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do the push rod tubes touch the fuse down there? If so you could let some fast CA run down the tubes to where they touch.
Rick K
LSF 6493
Rick K is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
