cg for Omega 1.8e and prop question
CA
Well got Omega 1.8e together and flew once. Wasnt too sure about cg. The instructions said that should be at spar. In order to do I had to add about 1/3 oz to front. So decided to tear apart and rebuild. Moved servos forward and battery is touching motor now. Still the cg is about 1 3/4 inches from leading edge (as measured close to fuselage) Dont know what else to do. I shaved everywhere I could. I dont have weight now, but still missing recommended cg by about 1/4 to 1/2 inch. I have a 3s 2100 battery so giving alot of extra weight. I thought I could get away with a 3s 1500 but I'd really have to add more weight. Right now the Omega weighs in at 24 oz
Im running a axi 1215/20 swinging a 12 x 8 prop. Flys fairly slow. Which is ok for now. Im only pulling about 8 amps. Any recs on a different prop?
I attached a pic so you could comment
