battery for small glider
I am getting into flying small gliders and am having trouble finding small battery packs for the radio. My local hobby shop can only get down to a 550 mah size. I found nothing small in the Tower catalog. The directions for my Zagi thl kit say to use a 110mah to keep it light. Any sources would be helpful. Thanks, SR
CA
RE: battery for small glider
I wouldnt go below 270mah. That gives you well over an hour on a charge, and with the 110 I bet you end up with nose weight anyway, even in a THL. I used 270's in the Zagi LE's I used to combat.
