Scale TG-3A Short Kit
My Feedback: (15)
Received my TG-3A short kit from Tom Martin, I opened the box and I have to say, I almost hate to take and utilize the lazer cut wood to construct my kit. Excellent lazer cutting, a fat plastic bag full of quality accessories, well printed and rolled set of plans and a clearly printed construction article. Thanks Tom for delivering what you promised, a quality kit for the money.
My Feedback: (35)
RE: Scale TG-3A Short Kit
Red
I have the I-26 short kit waiting for winter building season. My reaction to opening the kit was the same as yours - WOW! The quality is nothing short of excellent down to the most minute detail.
When I ordered my kit, delivery was delayed due to a change being made in the plans. Tom was up front and communicated very well during the delay. He is a class guy and somebody I would have no hesitation about dealing with again.
For anybody thinking about a scale sailplane, this is the way to go!
papermache
papermache
Keep the updates coming, Redtail! Pics, clever build techniques, equipment installation, etc. I'm doing this one, too. You going with ailerons and spoilers like me?
Dgliderguy
Dgliderguy
MO
Thanks for the kind words guys. I just stumbled across this thread. We are getting closer to releasing the Cherokee II kit with great input and assistance from David Smith... soon I hope since this will be an exciting model and is very unique and well designed...... The SA 1-30 kit is nearing completion to ship in the smaller 1:8 scale for micro tow and the quarter scale is close behind. We think Saito 300 or BME 50 for power and we have allowed room for the 32 oz. tank from Sullivan!
And the latest is we have gotten permission to kit Dick Graham's great 1980 Nats winning scale Piper Pawnee. Plans are scanned and work on parts starts in just a few weeks. Should be shipping by September. Same power options as the 1-30..... 108" of raw lifting power with 10 pounds of tootsie roll capacity desinged in.
My laser cutter is having difficulties with his health and the heat this week so I am a little later than anticipated on shipping several kits this week and last. Will throw in an instrument panel kit for those of you that have been most patient.
As always, thanks for your support, I appreciate your business,
Tom
Tom
MO
The ulitmate scale towplane, our quarter scale Piper Pawnee is being cut as I am writing. Its off to the beta builder Saturday and he has a HUGE bag of goodies coming his way from SIG. This is the lineup of parts as it now sits for this first ever laser cut large-scale Piper Pawnee. You guys thought you had a grab bag full of cool stuff, check this out.....
Piper PA-25 2.7m Span
Span: 108"
Length: 72"
Area: 1700 in.2
AUW: 18-22 lbs
Power: 42-62cc
Functions: Rudder, Elevator, Aileron, Flaps, Throttle, Dusting Hopper or Tow Release, Choke (optional)
KIT BILL OF MATERIALS:
LASER CUT PARTS
PA-25 2.7M_01 18_4X32 - right wing ribs sheet 1
PA-25 2.7M_02 18_6X32 - right wing ribs sheet 2
PA-25 2.7M_03 18_6X32 - right wing ribs sheet 3
PA-25 2.7M_04 18_4X32 - left wing ribs sheet 1
PA-25 2.7M_05 18_6X32 - left wing ribs sheet 2
PA-25 2.7M_06 18_6X32 - left wing ribs sheet 3
PA-25 2.7M_07 316_6X18 - Turtle deck stringer notched formers fore and aft
PA-25 2.7M_08 18_4X18 - Instrument panel bulkhead and cockpit rear decks and rudder horn mount
PA-25 2.7M_09 18 PLY_12X12 - Firewall doubler and strut mount plywood rib and tail wheel mounting plate
PA-25 2.7M_10 14 PLY_12X24 - Firewall and all wing and tail shaped tips and edges
PA-25 2.7M_11 332 PLY_4X12 - Wing root ribs
PA-25 2.7M_12 18 PLY_12X30 - Fuselage right side plywood doublers and triplers
PA-25 2.7M_13 14 PLY_12X30 - Fuselage left side plywood doublers and triplers
PA-25 2.7M_14 116 PLY_12X18 - Fuselage lower hatch cover plates and doubler frames
PA-25 2.7M_15 14 PLY_12X24 - F2 and tank compartment floor
BALSA
3 QTY. SIGB067 1/4" x 1/4" x 48" Stringers
6 QTY. SIGB062 1/8" x 1/4" x 48" Stringers
7 QTY. SIGB071 3/8" x 3/8" x 48" Longerons
4 QTY. SIGB041 3/8" x 3/8" x 36" Longerons
1 QTY. SIGB019 1/8" x 1/4" x 36" Vertical fin
1 QTY. SIGB034 1/4" x 3/4" x 36" Vertical fin
1 QTY. SIGB496 3/16" x 3" x 36" Hard Balsa
1 QTY. SIGB307 1/2" x 3" x 12" Balsa Block
4 QTY. SIGB272 1/2" x 3" x 6" Balsa Block
2 QTY. SIGB308 1-1/2" x 3" x 12" Balsa Block
11 QTY. SIGB160 1/8" x 6" x 36" Balsa Sheet
SPRUCE
1 QTY. SIGGYS011 1/8" x 3/8" x 36"
2 QTY. SIGGYS035 1/8" x 1/8" X 48"
1 QTY. SIGBD005 1/4" DIA. X 12" Hardwood dowel
1 QTY. SIGBD002 1/8" DIA. X 12" Hardwood dowel
1 QTY. SIGGYS018 1/4" x 1/4" x 36"
HARDWARE
1- SUL395- Sullivan tank 32 oz.
3- RO308- Robart Pin Hinges
3- ROB331- Robart Ball Link Control Horns
1- 1/4 Scale Klett Tailwheel
1- DUB518 - 4-40 Pull/Pull Rudder Kit
2- DUB450TL - 4.5" Main Wheels
1- 3" White Spinner
1- DUB141 - 3/16 Wheel Collars
8- SIGPMPB280 - 080 Brass Screws
1- SIGBS018 - Brass sheet
3- KS103 - 5/32x12 Aluminum Tubing
1- KS256 - .032x4x12 Aluminum Sheet
4- KS255 - .016 Aluminum Main Gear
1- SIGGB006 - 1/16x2x12 Tempered Aluminum
1- DUB179 - 6/32 Cap Screws
3- DUB379 - 4-40 Control Rod for all surfaces
3- DUB902 - 4-40 Ball Links servo connections
1- DUB511 - Antenna Tube
1- SUL503 - Golden Rod for Throttle linkage
2- SULS547 - Flying Wire Brackets for tail.
2- SIGSH108 - 4-40 Flying Wire Brackets
1- SIGSH554 - Elevator Control horn
2- TMRC PA-25CP - .030x12x18 Plastic Sheets for Canopy
1- TMRC PA-25MG - 3/16 Landing Gear wire (3)
1 pkg. flying wires and crimps
1 fiberglass engine cowl PA-25 125
2 front strut fairings, left and right
2 rear strut fairings, left and right
.040 plastic canopy material
2 sheets plans, rolled
Optional scale instrument panel laser cut kit and plans
Optional scale functional dusting hopper laser cut kit and plans
Optional full flight pack with all digital servos
Optional BME power package
Span: 108"
Length: 72"
Area: 1700 in.2
AUW: 18-22 lbs
Power: 42-62cc
LASER CUT PARTS
BALSA
SPRUCE
HARDWARE
1- 3" White Spinner
