how do you build light ?
RE: how do you build light ?
You can build light and still have strength. It comes from careful structural analysis and selection of material to suit the job. Also tapering from strong and rigid to weak and light in a tapered way to avoid sudden transitions that form stress points. It also comes from knowing where and what NOT to use. It's also important to avoid the urge to build strongly enough to resist crash damage. If you try to do that it'll certainly come out heavy enough that you'll find out just how well it does in that area. And actually light and flexible models actually will often resist crash damage better than heavier ones.
It also helps to build in a lot of air......
as always great tips BM !! thanks, iam afraid i overbuilt my GL to resist crash damage ,i used a alot of epoxy and spruce spar stiffeners
to beef up wing center section, also fuse was over glued , the model seems a bit on the heavy side,
also put in a down plane locator and a switch harness that adds a small amount of weight but used micro servos and no decals
just trans ultracote to loose some weight
WI
you need to take a couple of elements and knock them together, hopefully during the exchange you will kick off a photon or two. Viola instant light.
