Hyper DLG Assembly Instructions?
VA
Does anyone have experience assembling the [link=http://www.nesail.com/detail.php?productID=3059]Hyper DLG[/link]? I just purchased one and it did not appear to come with assembly instructions. Most of it's pretty straightforward, but I'm not sure about mounting the servos in the fuselage pod, and there don't appear to be precut slots for the control horns. Also, the horizontal stab appears not to be symmetrical. Does the high camber side go up or down? Thanks for any help.
CT,
RE: Hyper DLG Assembly Instructions?
I have the Hyper and cut out servo holes inline and off set to alternate sides with control rods running down opposite side..if that makes sense. Also cut away near nose to add lead, small hole. If you go to RCGroups search Fireblade. Thats its euro name.
Killer
Killer
