Tug Tow Hook Location
G'day I was just wanting to get some kind of consensus as to where the most common tow hook location is for the Towplane. I believe it is arround 10-12mm behiend the C of G on the top of the towplane. and thoutghs would be welcome.
AZ
RE: Tug Tow Hook Location
Yes, right behind the wing on the top of the fusilage like Rocket said works great and is an easy install becouse the wing is not involved.
Some guys put struts from the tips of their elevators to the top tip of their vertical fin. Not for structural reasons, but to alow the line to move side to side without snaging on the fin.
Just curious but I've noted that most RC aerotow airplanes mount the towing line somewhere as mentioned above. Why is the hook and line not mounted at the tail per full scale?
AZ
ORIGINAL: Michaelj2k
...but I don't know if this is just a fear or if pioners of RC aerotow had some bad experiances. Anyone know?
My Feedback: (8)
The reason we tow from the this position is that it is impossible to stay safely behind the tug(as in full scale) Towing from the T.E. allows the sailplane a big "fudge factor", preventing it from pulling the tail of the tow plane all over the place!
Randy
Randy
