Aileron hinges
PA
Aileron hinges
Hi all:
Just purchased an ArtHobby Hybrid DL (my third glider from ArtHobby: already have a Hyper DL and a Thermic 2.5, both excellent fliers), and will be using full-span flaperons. Here's my question: I've always hinged my ailerons on BOTH sides (the top of the wing-aileron, and in the "notch" underside). Is it possible to get away with just using ONE length of tape along the top of the wing-aileron and not worry about getting another piece in the notch? I've heard two different sides to this one, and am just looking for advice...
CA
RE: Aileron hinges
Sure, just one layer of tape will do fine. I use Scotch #190 tape available at Ace Hardware, Orchard, etc. Since youre doing a DLG, if you really want to go crazy you could cut the tape in half width-wise to save some weight.
You miught want to Google "silicone hinges" just for the heck of it.
PA
RE: Aileron hinges
Thanks, Slope, for the advice. I did in fact Google silicon hinges, and I'm very interested in giving it a try. Seems to be a bit of discussion about what kind of silicon and what kind of masking tape to use for a good result... any advice there? Have you done this before? Any assistance would be appreciated before I screw up my ailerons
PA
RE: Aileron hinges
Sounds like that tape will last longer than my glider, which in a couple of cases isn't really saying much
Any other recommendations for brand of tape? I'd like to try the UK verson, if the import tariffs arent too high...
RE: Aileron hinges
Hi there.
I've not seen "Diamond Tape" for a few years now..........is it still produced ?
Another alternative is Scotch "Magic Tape", which I know is still available.
CA
RE: Aileron hinges
E-6000/Goop/Shoe Goo makes a very tough hinge. Silicone, of course, is an ol' standard. Supposedly the aquarium silicone is the best choice.
3M #190 is what I use. It comes in clear as well as the primary colors, PLUS Krylon sticks to it so you could hinge, then paint your plane, which I've done on a plane thats 4 years old.
RE: Aileron hinges
ORIGINAL: slopemeno
Sadly, we don't have the same amount of variety of products in the UK............unlike you guys across the pond.
CA
RE: Aileron hinges
Look for E-6000 in plumbing supply places. I have heard of guys in UK finding it that way. It might also go by "Ecclectic-6000". I know you guys arent innundated with all the crap., er, products we sometimes are...It eats EPS so seal the foam with some thin epoxy first.
RE: Aileron hinges
ORIGINAL: slopemeno
