spirit spar
spirit spar
i broke many spars with my great planes spirit. Should i make one out of aluminum? Or some other king of wood? I usualy make them out of plywood of uluminum.
RE: spirit spar
If you're talking about the wing joiner, in my case I'd use plywood, or aluminum sandwiched between plywood. Plywood is very resistant to shear forces.
RE: spirit spar
Do you tape the wings? When the wings are joined some electric tape would add strength to the join. In my case I used the stock joiner and then glue the halves. Never had a problem and I have hi-started it very hard.
Take care.
Take care.
AZ
RE: spirit spar
Race....
the absolute lightest and best way to strenghthen built up sailplane wing spars is to adhere carbon fiber tape to the bottom of the bottom spar member with epoxy. since when under launch and flight loads, the bottom spar is under huge tension and the top spar is being compressed, it does little good to put carbon fiber any where on the top spar....additionally,
making sure that the shear webs fit well, and are securely glued to both the spars and each rib is extremely important. these bits of balsa form an I-beam of the spars and contribute immensly to the overall bending strength of the wing.....
RE: spirit spar
ORIGINAL: aeajr
... I tape mine together with 2" clear packing tape It is almost as strong as glassing them together.
RE: spirit spar
ORIGINAL: guru_dick
How do you avoid tear off Monokote when you take off the tape?
ORIGINAL: aeajr
LA
RE: spirit spar
What event is causing you to break the joiners? I just don't understand what is happening. You are just hand launching this plane? If you are pulling down on it when you throw it you might be putting enough stress on it to break it. Otherwise, what's happening is a mystery to me.
Do you have two piece wings? I assembled mine with the standard joiner as a one piece wing. It has never broken and I destroyed the original fuselage and one wing tip in a "radio off" high start launch. The wing center and joiner survived just fine.
If you have built it as a two piece, I have a design that you can use that would probably be stronger than the stock setup.
EJ
Athens, LA
EJ
Athens, LA
RE: spirit spar
well after some more handlaunches and broken pieces i taped the wings together with packing tape and made the spare smaller and taped arround that. now it hasnt broken yet. Now I have my friend run with a string with a ring hooked on the loop on the plane and it goes up about 150 ft.
CA
RE: spirit spar
ORIGINAL: jschuring
. . . the bottom spar is under huge tension and the top spar is being compressed, it does little good to put carbon fiber any where on the top spar...
Put the carbon fiber strips on the top of the top spar - a strip on the bottom of the bottom spar is nearly useless baggage.
As another note, the grain of the vertical shear webs should be vertical, to transfer loads from one spar to the other. If the grain is horizontal, they will shear in half under relatively little load.
