Accipiter Badius Flight Time
Hi,
This is one for any Accipiter Badius flyers. I've recntly purchased an Accipiter Badius from Ebay (model number 3380-1) and I've been very impressed with the build and rigidity of the model. I'm looking to take it out on a first flight soon. The only information missing from the instruction that came with the glider is the recommended flight time.
The glider comes with a 7-cell 8.4v 600mAh battery pack. I can't find anyhting on the interweb thingy machine that recommends how long to keep the glider in the air before you lose control of it. Can anyone here give me a rough idea from their experience of the best flight time before bringing the glider back to earth?
Any advice would be much appreciated.
TX
RE: Accipiter Badius Flight Time
Depending on the amount of thermals in the area (will thermal well in good thermals only), you get about 5-7 minutes of lfight time if you are conservative with the throttle. Good airplane for a trainer, as it is cheap and easy to repair/replace. I got rid of mine after about a year and now am into gas/real gliders. Have fun!
Many thanks for the info. 5 - 7 minutes doesn't seem that long though! If I were to replace the battery with say and 8.4v pack that has a higher mAh rating, would this give a longer flight time or would a higher mAh rating fry the receivers? (apologies, but I don't really understand the intricacies of electrics/batteries, etc)
The Accipiter Badius is a great model for the money. With a few mods it will fly 15 minutes or more. By setting up a good climb rate and letting it go it will go out of sight if you let it. This is with the stock battery. A sketch of my few mods is attached.
i have one, and on the stock bettery i get about 13 minutes continuous flight, well over 20 mins if i glide. I made a new battery pack from rechargeable McNair 800 mAh AAA that i got off of ebay, $10 for 16, enough for 2 packs and a couple extras. That new pack has about 18 minutes flight time with full throttle. Yesterday, with both packs and a lot of gliding ( i had it up about 200m above me), I had it in the air for over 45 minutes, and thats without updraft.
