WILL THIS WORK
My Feedback: (27)
WA
WILL THIS WORK
need suggestions for a 1.5M hotliner @16oz dry........ran across a e-flite 480 1020 KV outrunner and claims itll swing a 10-11-12 prop with good torque at around 26-30A let me know what you think about this setup chow
RE: WILL THIS WORK
I've got a 480 and only ran it on 8 nimh cells with an APC 10x6. It was enough to haul my 30 oz model almost vertical. If you really can keep your 1.5 meter model down to 16 oz then you'll easily be able to run it on two cells at around 20 amps and climb vertically right up and out of sight with no issue at all.
