over 100" sailplane
AZ
Any glider out there similar to the Spirit 100, that has all the functionality(RES + aileron and flaps) of the Spirit just bigger. That I can build. Because size does matter?
Thanks in advance
Justin
Thanks in advance
Justin
CA
Why not look for a clean, used TD plane? Something like an RnR Genesis or Thermal Millenium, or an F3B Eagle? Planes like this are usually hollow molded or sheeted obechi over foam, and span around 120" or so.
I've managed to pick up a couple like that for very reasonable prices. I recently got a 10-15 year old Ron Vann Spectrum for $100, including the six servos. I picked up my RnR Genesis for $350 with six servos as well, and that plane flew great.
My Feedback: (18)
NE
ORIGINAL: jmraa767
Thanks in advance
Justin
Thanks in advance
Justin
I'd also lengthen the fuselage a bit and add a bit of area to both horizontal and vertical stabs.
This would give you a model in the 3.5 meter range and depending on your "scrap" bin, should cost only slightly more than the basic wood kit.
My Feedback: (132)
PA
You could look at the Sky Bench Aerotech Challenger. 145in span, all wood with RES and flap. Flap could be set up as flaperons with a computer radio.
Saw one of these (I believe flown by the designer) back in the 70's at the Harris Hill L/D contest come in for a spot landing he seemed high but at the last moment he popped full flaps and spoilers and placed that nose right on the 100 point ring. It was one of the most beautiful landings I have ever witnessed. It was not a dork landing but one that put no more stress on the plane than if he placed it there by hand.
Hey take a look.
Mark
Hey take a look.
Mark
I've always liked the Majestic.
http://www.mountainmodels.com/produc...roducts_id=175
And then there's the Big Bird from Skytech.
Or if you want large and graceful find a way to build a Grand Esprit perhaps with updated airfoil and wing construction.
ORIGINAL: jmraa767
Thanks in advance
Justin
Thanks in advance
Justin
AZ
Thanks for all your ideas. I'm still undecided at this moment. I have been contacted by a guy with a Challenger for sale(fibergalss fuse.) that will make a lasting project. But I will probably look at something else in the interim.
Thanks again
Justin
Thanks again
Justin
