ARF
AL
ARF
Where can I find a good 70 to 80", two piece wing, electric, folding prop sail plane ARF? Would prefer it came with motor and speed control.
Frank Baity
AMA 38026
Frank Baity
AMA 38026
AL
RE: ARF
I found the Easy in Tower add. Although this is the size I am looking for it sounds like it is a foam wing and fuse which isn't to my liking. I am seeking fiberglass fuse and build up wing....may be foam wing if I must.
Frank Baity
AMA 38026
Frank Baity
AMA 38026
MO
RE: ARF
Seen one of the at the lhs last weelend i belive it was an e-flite cant remember which model now but it was Reciever ready servos installed speed control folding prop 2piece built up wing looked pretty good for $189.00 almost bought one but had other things on my mind, who knows maybe this weekend
MO
RE: ARF
I havent seen one fly either all ive been flying is dlg's would be kinda nice to have an electric one they didnt look to bad, heck if its underpowered im sure ive got and extra motor laying around that would work, might have to buy one just to see if it is.
RE: ARF
I saw the new Accent to day at the hobby shop. It all there but for the battery rec. It has all you asks for and is almost ready to go. The only draw-back is the wing span is a little short. I had the early one and needed to be modified to make fly, all that was corrected in this one.
