Radian Problem..bec/batttery
This is a new RTF...I turned on the transmitter then pluged in the battery last night and I had control of the servos and motor.
Tonight I was doing a final mock up and nothing works after turning on the trans...then plugging in the charged battery!!! The bec signals a tone then beeps 3 times when it attached to the battery,...but I have no control from the trans. anybody have suggestions
RE: Radian Problem..bec/batttery
Not sure if it will help or not, but try turning throttle trim all the way down on transmitter, as it will not arm unless it senses that the throttle is "off" all the way. Hope that does the trick, if not it doesn't sound to serious as you are getting the beeps at least.
I seem to have solved my problem...I re-binded the receiver and I have control of the servos now....only thing now is the trim adjustment which worked for a mintue quit on the rudder...the rudder works but no trim adjustment.....don't know what to say
