3-4m semi-scale thermal glider, which one?
CA
RE: 3-4m semi-scale thermal glider, which one?
have a BOT that was built up from a kit and it handles wind very easly. If you have some lift it will stay up for ten minutes or so when launched by a winch. It depends where you live a lot as here in the Desert it is hard to find lift most of the time. Many guys are using motor gliders because of this and I have one that has stayed up for almost one hour. let me know what you want and I will try to help. Warren in the Desert.
