RC Gliders, Sailplanes and Slope Soaring Discuss rc gliders,rc sailplanes and slope soaring in this forum. Thermaling techniques, airfoils, tips, etc
Polydihedral question?
Old 10-01-2009, 10:18 PM
liftdump
Default Polydihedral question?
I just finished building a Dynaflite butterfly and the wingtips are about 1/4" difference in height up from my work surface when each panel is laid side by side, trailing edge to-to trailing edge. The total wingspan is 99." Is this insignificant? Does anyone know if this will be noticeable with the flight characteristics? I have not checked the distance with the wing seated on the aircraft yet. The dihedral could possibly offset this but I was just curious at this point. I might be able to knock some of this down when I cover it. Any input or opinions are appreciated -thanks!
-M
Old 10-01-2009, 10:51 PM
soarrich
My Feedback: (98)
soarrich's Avatar
Default RE: Polydihedral question?
You won't notice it at all.
Old 10-02-2009, 03:13 AM
Tinkrerpilot
WHat soarrich said. The only one that knows is you. And those that see this thread. It will not be of any problems.
Old 10-02-2009, 08:18 AM
liftdump
Thanks!
Old 10-02-2009, 08:44 AM
skeeter_ca
skeeter_ca's Avatar
I won't tell.
skeeter
Old 10-02-2009, 09:00 AM
snuts
If anybody suggests that one of your wing panels "is a little off", ask them which one?
Be more concerned about sufficent, and similar washout for your test flight. Enjoy your Butterfly, thousands have -good choice-
-Snuts-
Old 10-24-2009, 07:15 AM
aeajr
aeajr's Avatar
Do a lateral balance on the plane. One wing that is heavier than the other will likely have more impact than the slight difference in dihedral. Add weight to the wing tip of the light wing.
