Replacement wing and airfoil for the Horizon Aspire
I have a Horizon Aspire with a damaged wing. I think it would be easier to build a replacement wing then repair the existing wing. I was looking for some suggestions on airfoils for my new wing. While I am a LSF 3 with all but my tasks done for level 4. I am not very active in gliders presently. I fly it at our annual Club fun fly on January 1 so it needs to be pretty much a min sink wing. Yet have some penetration if the wind comes up. I am using only R/E so I can keep the polyhedral and basically the same 2m plan form. What do you guys think?
Sparky
Sparky
It's funny but I keep suggesting the Mark Drela wing section from the Allegro Lite but I have yet to build anything using it....
How about the AG 34/35 from the Mark Drela Allegro Lite?
Seriously though, I really like the precept of extending the sheeting to control the airflow separation over the rear past the high point that Mark uses on that design. His option for building the wing spars would result in a bombproof wing but I really don't think you MUST go that route. Especially with an Aspire fuselage and it's drag holding you back the launces may be better at a slightly more same pace anyway. 1/8x1/2 spruce with carbon tape top and bottom is a find compromise for easier building. But if you do use Mark's full carbon spar system I doubt if you would regret the extra time needed.
