electric bot.
RE: electric bot.
I'm using an AXI 2820/14, a 40amp ESC, and a Aeronaut 13x6.5 prop on an aluminum spinner.
2 3s1p25c2200mAh packs in parallel. I'd rather be overpowered than under.
RE: electric bot.
My Paragon is about the same size and weight as a BOT. I used an E-Flite Power-25 outrunner with a Phoenix -45 ESC and a 10 X 7 folding prop. I get several climb outs on a single charge with a Lipo battery.
A BOT and a Paragon are a lot alike in flying characteristics in that they're both floaters and will only benefit from the weight of the electric power system.
