cox medallion .09 engine, what glider to put it on? BOT?
A guy at work overheard a friend and I talking about airplanes and he mentioned he had a ton of old stuff he'd give us...
Well it was treasure for me, I got a brand new in the box cox medallion .09 engine with the muffler throttle...
I"ve been wanting a larger 3m glider and this seems perfect but I'm not 100% for sure.
Is the .09 large enough?
I'm thinking maybe a bird of time arf with a power pod?
What do you all think / reccomend?
Any affordable ($150) 3m arfs out there? What would you all put it on?
RE: cox medallion .09 engine, what glider to put it on? BOT?
It may be able to "glide uphill" but the climb would be weak unless you can build the BoT to a very light overall weight. A better option for your Meddalion engine would be one of the older classic 100 inch span models.
I have a Tee Dee 09 on a 100 incher and she does fly ... using an 8x4 prop. Fuel is 15%. Use 20% or 25% for more power. I would say this glider is the max I would hang on this engine. She does snap props though, the plane has a good deal of momentum and if the prop doesn't finish horizontal, the prop snaps. I would like to find a folding prop that will take 15,000 rpm.
