Hacker Motor Problem
ll
I have a sailplane with a Hacker B20 18L motor with a 4:1 gear box. I managed to bend the prop shaft today. I am looking for information on replacing the shaft or gearbox. I have not been able to locate a supplier on the web that could provide the gearbox or shaft. Any help would be appreciated. Thanks in advance. |
Hi,
I have never seen just the parts for the gearbox, but NeuMotors many have the box. Looking for the Maxon P16 http://neumotors.com/NeuMotors/Gear_Drives.html |
Have you tried the USA Hacker Motor distributor in Kansas? I purchased several motor shafts from them recently. The website is https://hackermotorusa.com/ If your browser is like mine, it may give a security certificate error message when you try to open the tab. Should that make you nervous, use their telephone number, (913) 214-6995.
Allan |
YOu can contact Hacker directly:
http://www.hacker-motor-shop.com/e-v...&t=3&c=21&p=21 at the bottom of the page -> "Contact" /Bernd |
Originally Posted by BerndBrunner
(Post 12133597)
