Pitch 0 to 24 degrees after rebuild. What did I do?
I'm getting pretty good at the hover and forward flight but I'm practicing side ways and nose in stuff now.
So, I crashed my TREX 500 ESP. I bent the Main rotor housing, Feathering shaft, trashed the main gear, tail gear and main blades... It took a couple of weeks to get all the replacememt parts together and I got it all back together and can't figure out why my pitch is way out of range.
I have the Spectrum DX8 and in those weeks of waiting, I messed with a few settings. I can't remember which ones though.
What did I do?
I disconected the motor and measured the pitch it at half throttle and it was about 12 degrees. At full throttle is way off the charts. I think it's about 24 degrees.
What the heck did I do to get that much pitch?
Did I put it together with the wrong or mess the controller's setting too much?
Thanks for any help,
Ray
What did I do?
Ray
RE: Pitch 0 to 24 degrees after rebuild. What did I do?
The best thing for you to do is start from scratch, set your radio to default and set everything to 90 degrees on your heli and go from their.
