where can I get small hardware
I need set screws , washers .screws.spacers
I don't want to buy a new fly bar support just to get the 2 small washers for it
I also want to replace the little cup washers with flat washers on my main frame
RE: where can I get small hardware
there is an online place called something fasteners. rcfasteners...hobbyfasteners???? I dont recall but have seen mention of them here as well as maybe an advertisment on this site.
All they sale is screws, bolts, washers, etc... I dont know if they have a minimum order or not. Probably be worth it to buy a selection to have on hand if you go that route.
Like Morgan said...hardware store might be a possibility. Not for me though as Ive checked the small mom n pops stores here as well as the big box stores and about the smallest they go is 4mm.
ORIGINAL: Rafael23cc
[link]http://www.microfasteners.com/[/link]
Get one of their assorted "boxes" and you will be set for a number of field fixes when you loose a bolt in the tall grass.
Rafael
Rafael
as far as local hard ware stores go I can't even find a screw to use for blade balncing (the largest screw on the heli)
same for local hobby shops all I have found is parts for rc cars that come with screws
