RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
probably just another stupid question
Reply
Old 05-11-2002, 03:11 AM
chuppachup
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default probably just another stupid question
How do you keep your flybars parrelel to the ground when getting a pitch reading from the pitch gauge?
chuppachup is offline
Old 05-11-2002, 11:56 PM
Fastsky
Fastsky's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default HUH ??!?
Maybe its just me, but could you rephrase the question? As it is I don't have a clue what you are talking about!
Fastsky is offline
Old 05-12-2002, 12:28 AM
jmulder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try the Heli section
jmulder is offline
Old 05-12-2002, 02:33 PM
chuppachup
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Im sorry! Wasnt thinking when I asked. How do you keep the flybars level when finding the pitch?
Old 05-12-2002, 02:43 PM
Hivoltage
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default My Hand
I grab it with my hand, and hold it level. Pretty simple, eh?
Hivoltage is offline
Old 05-12-2002, 02:55 PM
=XGC= OzZ
=XGC= OzZ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default there are fly bar holders
They keep the fly bar strait.
Is this what you are asking?
=XGC= OzZ is offline
Old 05-12-2002, 02:56 PM
rdalcanto
rdalcanto's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default pitch gauge
Yes, in fact you need a bubble leveler to make sure the flybar is level. The other option, is if you know the main blades have the same pitch, because they track properly, then you split the difference to get the true reading. In other words, if your flybar is 2 degrees off level, one blade will read 12 degrees, the other 8, and you know they are actually at 10. This requires that the flybar is locked in position while you take the two readings, either by a clamp, tape, etc.
Rick D.
rdalcanto is offline
Old 05-12-2002, 03:06 PM
Scotty740
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There are several types of flybar locks. One is a clamp for the tailboom and a rod extends up to the flybar with another locking clamp there. Some people jam pieces of wood into the head to hold the flybar locked.
Like the others here I just hold it level with one hand while I check pitch mostly. I have a level on my pitch gauge and can tell when eveything is level.
Scotty740 is offline
Old 05-12-2002, 08:37 PM
syclic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Or simply sight the flybar to the horizon, then sight the pitch guage to the flybar.
syclic is offline
Old 05-13-2002, 12:49 AM
RS2K
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Does it matter?
Don't the main blades move with the fly bar? If so then it wouldn't matter where the flaybar is aslong as you use the flybar to check the pitch.
RS2K is offline
Old 05-13-2002, 07:11 AM
Flying-Cowboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
usually the pitch gauge has tabs you can allign up with your flybar, as long as it's semi level it's close enough. rs2k is right about the pitch moving with the flybar. this really isn't the space shuttle we are dealling with. yes they do make bubble balancer's for the swash plate and flybar locks but they are a waste of money.......
Flying-Cowboy is offline
Old 05-13-2002, 01:14 PM
Ergo60
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I also used a flybar lock in the beginning, but then noticed that it did not matter what angle my flybar was at. I use the Minature Aircraft pitch gague, and you sight the flybar with it for making pitch measurements. It is a little hard to explain without pictures, but even if my flybar was tilted fully forward I got the same pitch measurements as when it was held level with the flybar lock. So the lock was a waste of money.
Ergo60 is offline
Old 05-13-2002, 08:27 PM
Scotty740
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Brian,
That is not always the case. You can tip the Raptor flybar or some others and it doesn't affect the pitch reading. I know if I tip the flybar on my X-Cell it changes it quit a bit. It all depends on the mixing ratio that the head was desinged with. Some you can get away with the flybar not being level and on others you have to have the flybar at 90 deg angle to the mast. It's good practice to have the flybar parallel to the tail boom just in case.
