which one to get
which one to get
I've made up my mind and im going to buy a raptor 30.
I dont know if i should get one (nib)or one already setup.
I plan on getting rays authoritive manual on rchelicopters and learning as much as i can.
Please help
Please help
My Feedback: (14)
AL
which one to get
The prebuilt heli's are put together on assy. lines by someone you do not know. There's things you must take into consideration when deciding to buy a NIB kit or prebuilt.
I always advise buying a kit and building it yourself, it helps you develop your skills of becoming familiar with each individual parts. There is a lot more to building a helicopter than just assembling it. The manual specifies area's to check and balance & lock tite is a must were directed to do so. Without locktite every bolt can and most likely will loosen or fall out and will be a accident waiting to happen. Most of these ARF kits I bought was purchased only because there were low on kits and these are usually whats offered with or without an engine. Sometimes you save buying a engine at the same time you buy the kit & sometimes there's no price breaks.
If you do crash, if you didn't assemble the heli yourself, it's going to be hard for you to keep a good eye on maintenance and rebuild from incidents likes tip overs-boom strikes and etc.
I believe building a kit, is the first hands on experience that should always be done to familiarize yourself for the intriguing road ahead of RC Heli's. Just my 2 cents worth..
