JR XP6102 throttle ratchet
PA
I want to remove the ratcheting action from throttle on my JR XP6102 radio. I tried to
loosen the tension bolt as much as possible but, the ratcheting is still there. I removed
the metal plate that makes it ratchet, but now the throttle is dangerously loose. I might
try to turn the plate upside down to see if it tightens it. Any advice???
Thank you!
Thank you!
VA
RE: JR XP6102 throttle ratchet
Just turn it upside down, reinstall it and tighten tension screw until it feels about right. JR does offer a smooth surface metal piece but that should work fine
ON, CANADA
iirc if flipping it over doesnt work you might be able to slip a piece of shrink tube over it. it should stop the ratchet but leave some resistance.
I don't know exactly how the JR throttle ratchet is designed, but on my Futaba, I took the back off and slipped a short (~1/2 inch) piece of fuel tubing over the tension bar so the ratchet wheel rubs on the tubing. I fly my heli and fixed wing giant scales with the smooth throttle and like it much better than the ratchet. Hope this helps.
PA
Thank you everyone for your help. I ended up turning it over and adjusted the tension perfectly without the ratcheting.
