Raptor G2?
AL
RE: Raptor G2?
ORIGINAL: ewok0412
Hey I was wandering if the Raptor G2 is a good stabel helicopter? I've been looking at it for awhile now but there isn't much info on it.
Thanks!
Thanks!
The real life Raptor V2 is very stable. Can't speak for the one in the simulator.
Good Luck,
d.tipton
RE: Raptor G2?
I mean this one http://www.nitroplanes.com/rag26ccrarec.html
I can't find any reviews on it. I might be getting it but I don't know if its any good.
RE: Raptor G2?
ok ewok,
i have this heli. its it the exact same thing as the walkera 36.
so i would get the 36 if anything.
mine came with a burnt out motor.
go for a reliable company.
i made a bad mistake that way.
hope that helps.
if you have any questions about it ask , id be glad to help
hope that helps.
AL
RE: Raptor G2?
ORIGINAL: ewok0412
Good Luck,
d.tipton
RE: Raptor G2?
Ok I have a few questions out of the box is it a good acrobatic? And is there any better thats uner 200$? Prefferbaly and outdoor electric, with acrobatics.
Thanks!
Thanks!
RE: Raptor G2?
well i brought mine back and got a falcon 3d. love it!!!!
very nice outdoors. also comes stock with lipo and brushless motor and hh gyro.
very nice deal id have to say.
RE: Raptor G2?
check this great deal
brushless motor and new esc.
http://www.ehirobo.com/shop/product_...oducts_id=3783
or this one with the full metal upgrade.
http://www.ehirobo.com/shop/product_...oducts_id=4042
i belive the second one is basically the first with all metal upgrade.
both have extra main blades and traing kit free.
RE: Raptor G2?
i have had my raptor g2 about 2 months now, last week i was out just hovering in my back yard, lost controll and smacked it against a table leg, my problem is that the piece i need to get it flying again, i do not see in the parts list, so i started looking in the dragonfly 36 parts list . same problem i do not see the exact part i need. but i did find it in the dragon fly 36 main rotor system upgrade kit. my question is will the rotor upgrade for the dragon fly 36 work on the raptor g2......hopefully i can upload a couple of pics so you can see exactly what i am looking for.....first and second pic. is the part i need
KY
RE: Raptor G2?
yes they are basically the same heli but the raptor has a better gyro i just ordered the full metal upgrade for the 36 on ebay and it works on my raptor fine
RE: Raptor G2?
Just got my Raptor G2 and managed to bust up both sets of blades so far. Yes I read the manual, made adjustments suggested STILL coldn't get the thing off the ground.
O.K. I admit it...this is probably NOT the copter for a novice.
Any suggestions would be appreciated
ID
RE: Raptor G2?
Hello Scruffeyboy, Have you installed a li-po battery? Here is a photo of mine the stock battery won't even get mine off the ground with the li-po it has enough power to fly.
RE: Raptor G2?
I just bought this heli for my fathers b-day and i was wondering if it is really necessary to install the lipo battery to get it off the ground? and how should i adjust the shaft to make it fly?
ID
RE: Raptor G2?
Feuer, You will need more than just a battery to make it fly. Unfortunately you will have to change the motor (pinion gear) in stock configuration or upgrade to a brush-less motor. Maybe mine was just a factory dud but I tried everything with stock motor and li-po, every adjustment possible with PIT and PLT and wouldn't even attempt to get off the ground. I finally installed a himax 2580kv Brushless with a 14 tooth pinion gear and 35 AMP ESC, you couldn't keep it off the ground. I borrowed the parts from a heli-max 400. I had to return them to my friend though so I bought the Align 430 BL motor and 35 Amp ESC with a 12 Tooth pinion and the thing about pulls your arm out of it's socket. So upgrade the stock motor and battery and you will have a great flying helicopter with power to spare. Let me know if you have any luck. Thanks
NY
RE: Raptor G2?
Hello i see you have a raptor G2 I got one a week ago and it won,t get off the ground is yours stock(motor battery) The motor and battery get super hot in about 30 sac. can u help?
ID
RE: Raptor G2?
Hey nuz, Yeah I had the same problem. I upgraded mine to the Align 430 Bl and 35 Amp ESC. It Rawks now. You'll have to put a brush-less, li-po and esc. then they fly great. If you need anymore help let me know.
ME
RE: Raptor G2?
You dont have to change the motor unless it doesn't work completly. The inner main shaft can be extended alittle and it fly be-a-utiful. Try this before buying all of this stuff
ORIGINAL: starcop
ID
RE: Raptor G2?
yeah I adjusted the inner shaft up and it still wouldn't fly in stock form. Mine had a stripped bolt holding the motor on and metal was in the motor. It got worse the second time I fired it up. You can see grey metal all over the magnets inside my stock motor. It would have worked when it was new had the factory not ruined the mounting bolt.
I'll sell the stock motor for 50 grand! Anyone want it?....
ME
RE: Raptor G2?
Mine flew pretty good, I was looking at them the other day and I have seen many different types of motors on them. Where did you get your Raptor from. Was your stock motor have a yellow sticker or no?
