Blade Cp 4-in-1
NJ
Blade Cp 4-in-1
Hello,
I just got my new blade on monday. When I go to fly the helicopter the red light goes on when there is enough power to takeoff. What would be causing that and how do you fix it? One more question would I dammage the battery charging at 1.2amps? I am using the stock battery.
Thanks in advance for your help.
Rsiaviaiton
Rsiaviaiton
CA
RE: Blade Cp 4-in-1
I also had that problem,took it to my L.H.S. they tried a new 4 in 1 ,same problem, the red light will blink but no green light, they said to call EFlight, looks like it might be the radio. I have about 20 flights on it, then last flight the motor started to cut out luckily i landed ok.. most likely will have to send it back to e flight
