debonding agent
debonding agent
i am new to this about 3 months now. i am trying to repair my blade cp. shredded the tall boom, i kneed to know what debonding agent i should use. i don't think i should use nail polish remover. i know i will use a super glue to put it back together. also should i use some typ of lubricant since i am also going to install the metal rotor head and swash plate along with an aluminum main gear.
thanks
thanks
TN
RE: debonding agent
The easiest way to debond CA is to use a monocote heat gun, if your working with plastic you have to becareful so as not to melt the plastic parts. Just use enough heat to remove the parts, this is by far the very best method. A second best method is to use the debonding agent that most hobby shops sell. It can take a long time to work so patients is a must!
Gary
Gary
