Raptor G2 Assembly HELP NEEDED
My Feedback: (126)
I bought my first heli, the G2, and it flew! I have learned a few things. Don't fly it in your basement out of the box and make sure you have a fully charged battery.
After replacing two sets of blades in the basement, I had a nice evening to take it outside. I was up about two stories flying an oval pattern when it took a nose dive into the snow. I thought I was thankful it was snow. well, It entered the snow at such an angle that it pushed up the main rotor blades forcing one blade to hit the tail boom, bending the boom and wiping out the entire rotor head and shaft.
I was hoping someone knew where to get a breakdown of the G2 assembly.
RE: Raptor G2 Assembly HELP NEEDED
Here ya go. Also, www.hooobby.com has been a pretty reliable source for parts. Shipping is a little higher since its China but I've dealth with them on many occasions.
Oh one more thing. I highly suggest you invest in a helicopter sim like RealFlight G3. It's around $200. It will pay for itself in the parts you wont have to buy crashing in the sim instead of your heli.
My Feedback: (126)
Thanks ewolow. That's just what I was looking for. I wish I knew that sooner. The Walkera parts are a tad less expensive.
I do have the G3.5 sim. And it's been great but it's still not the real thing. My problem was being stupid and taking off with a low battery.
I figure I'll know the G2 a lot better when I get it reassembled
Thanks again !!
Thanks again !!
ID
Hey phatbob02, I've been involved with a thread for quit some time on the Raptor G2 there is a lot of information there. I've been flying my Raptor for about 3 months now with full upgrades. The Radio will lose signal on a regular basis and it will tail strike or nose dive! You might want to trust me on this one. I replaced my radio because I have a t-rex 600 and a Mx400 and now I haven't crashed in a long time. The signal loss is why I crashed my Raptor on several occasions. I even had it go full throttle one day in my driveway. Be careful with this helicopter it has a mind of it's own. Here is the link, we have a pretty good following on the G2! starcop out.. http://www.rcuniverse.com/forum/m_50..._1/key_/tm.htm
ID
Hi phatbob02, I used my Futaba CH 7 PCM. I used the Exceed gyro it works great! I am going to replace the servos with S3107 I have four so I might aswell us them. I really like my Futaba 7 the only change I had to make for the Raptor is turning down the channel 6 End-Point. I have positive at 100% and negative to 0% this way the pitch servo in the helicopter has the correct range of travel. currently the stock servos work fine; but I like a more direct feel when I fly. The stock servos don't respond soon enough to stay ahead of the helicopter. starcop out... PS: I never fly my helimax because I have more fun with my cheap Raptor G2...
My Feedback: (126)
Yup ! Same radio I bought. I also bought the JR Mini Heli Performance ServoSet to use in the Helimax. I'll get a second receiver for the radio and give it a try in the G2. I should have all my parts for the G2 buy the end of next week.
I'm pissed about the factory radio but I guess you get what you pay for. I assumed my crash was battery but a radio failure makes more sense.
ID
Hey phatbob02, Oh I was "livid" to say the least. Helicopters can be an emotional roller coaster; one second your happy and flying- then blammo a crash. The thing that gets me is this helicopter has enough against it, weak frame, zero power motor, poor servos and then a bad radio. My radio is the only reason I was crashing. I could literally watch the helicopter go from a smooth hover to a slow backward desent and I'd use full forward and nothing. It would lose signal even after the crash and I was right next to it. You have to re-boot the switch in flight to get it back. Too hard to keep monitoring all that junk. Now I've re-built it several times; because it's cheap to fix. Helidirect.com has most of the parts for $2.75! Check them out, also hooobby.com has the aluminum head for $32.50 and the metal tail for $31.50. Well good luck, keep it up-right. starcop out..
i need a picture of the tail and blade assemblys for all cnc upgrade parts on a exceed rc raptor g2. The parts i am refering to are 50H08-80 through 50H08-90. I need all angles or detailed pictures of which parts and which screws go where. Can anyone help? I hope i am posting this in the right area......
